+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 585, Level: 5
    Join Date
    Oct 2009
    USA
    Posts
    7
    Points
    585
    Level
    Altium Question
    I am trying out Altium Designer Summer 09 to see if I want to switch from Eagle.
    I have look at many of the training videos on Altium's site and read some of the docs. So far I really like the interface but one thing that that I would potentially like to change is having to perform an ECO to update the PCB if I make a change in the schematic.
    In Eagle if you make a change on the schematic the PCB automatically reflects that change but in Altium you have to tell it to update the PCB. I'm sure there is a good reason but it is strange to me.
    Can someone tell me why it is good to have to tell Altium to perform the update?
    And is there a way to turn that off and have it update automatically?
    Thanks,
    Eric
    •   Alt23rd October 2009, 07:54
      advertising
  2. #2
    Full Member level 3
    Points: 2,904, Level: 12
    Join Date
    Mar 2006
    Bangalore
    Posts
    186
    Points
    2,904
    Level
    12
    Re: Altium Question
    hi
    it is good to tell altium to update the pcb, coz every time we can check what changes we made exactly on the schematic and the consistency between the pcb and schematic will perfectly work out.
    for simple designs it may not be problem.
    but for large design with several hundreds of components, it is difficult to check if a component on schematic is removed by mistake. Now, the pcb update inform those inconsistencies before going further.
    hope this info. helps u.
    regards
  3. #3
    Join Date
    Oct 2009
    USA
    Posts
    7
    Points
    585
    Level
    Altium Question
    That makes sense for large designs. Most of my designs are pretty small though but I'm sure I will get used to it in time.
    •   Alt23rd October 2009, 18:16
      advertising
  4. #4
    Join Date
    Oct 2009
    USA
    Posts
    7
    Points
    585
    Level
    Altium Question
    Another question.
    How do you setup default design rules to be applied to any new PCB designed. I know where I can set the design rules for a particular PCB but in Eagle I could load a set of rules in the DRC dialog but I don't see how to do that in Altium.
    Thanks,
    Eric
  5. #5
    Advanced Member level 2
    Points: 5,187, Level: 17
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    Altium Question
    In altium also you can import the Design rules for that you have to open DRC dialog and use RMC to open the pop up for the import or export rules option.
    1 members found this post helpful.
  6. #6
    Full Member level 3
    Join Date
    Mar 2006
    Bangalore
    Posts
    186
    Points
    2,904
    Level
    12
    Re: Altium Question
    hi ricky,
    I started using altium for simulating my designs. can we interface altium with matlab or simulink? coz the graphical features for simulating designs are not so good. i mean to say the CRO options, switch options which we usually find in other ECAD tools like multisim etc are not available in altium.
    Regards
    skr
    •   Alt26th October 2009, 12:44
      advertising
  7. #7
    Join Date
    Oct 2009
    USA
    Posts
    7
    Points
    585
    Level
    Re: Altium Question
    Quote Originally Posted by Anonymous_Ricky
    Great, that is what I needed.
    Eric
