+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 5
    Points: 2,644, Level: 11
    tendi's Avatar
    Join Date
    Jan 2006
    zimbabwe
    Posts
    87
    Points
    2,644
    Level
    11
    Eprom programmer
    I'm looking for simple software to use to view eproms type 24C02,24C04 and 24C08 and to copy/write into these tv memories. I also need the schematics for the hardware to use. I have tried the ponyprog with little success.
    tendi..
    •   Alt21st October 2009, 10:24
      advertising
  2. #2
    Advanced Member level 5
    Points: 13,540, Level: 27
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,960
    Points
    13,540
    Level
    27
    Blog Entries
    18
    Re: Eprom programmer
    Hai
    lancos.com
    here you can find serial port and parallel port programmers with software
    Nandhu
  3. #3
    Full Member level 3
    Points: 5,171, Level: 17
    Join Date
    May 2001
    Posts
    175
    Points
    5,171
    Level
    17
    try with willem program
    http://www.geocities.com/mpu51/eprom/eprom.html
    i have a willem progr PCB4V6.1 from silvotronic (http://www.silvotronic.de/)
    on inernet they are more version
    regards
    •   Alt21st October 2009, 23:41
      advertising
  4. #4
    Newbie level 1
    Points: 532, Level: 4
    Join Date
    Dec 2009
    Bavaria
    Posts
    Points
    532
    Level
    Re: request for eprom programmer software/hardware
    Hi all!
    Special to lee:
    What version of Softwar do you use for your willem programmer?
    I use the same PCB-Version, but i hav massive problems to read and write
    eproms (27c1001)
    Greets from Bavaria!
  5. #5
    Member level 3
    Points: 1,533, Level: 8
    Join Date
    Jan 2006
    Posts
    54
    Points
    1,533
    Level
    8
    tendi,
    Try www.batronix.com They have some very good eeprom programmers.
    ras
    •   Alt17th December 2009, 04:38
      advertising
  6. #6
  7. #7
    Junior Member level 2
    Points: 828, Level: 6
    Join Date
    Mar 2009
    Posts
    23
    Points
    828
    Level
    For a fully USB version of the Willem programmer with support, go to : www.mcumall.com.
    The GQ-4X is the best version, but you could do with the cheaper versions too.
    B.R.
