+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
  1. #1
    Full Member level 1
    Points: 2,472, Level: 11
    Achievements:
    7 years registered
    hkBattousai's Avatar
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    PIC18F2550, C18 - What setting to choose for CPUDIV?
    Quote Originally Posted by MPLAB>Help>Topics>Language Tools>PIC18 Config Settings
    PLL // Prescaler Selection bits:
    PLLDIV = 1	// No prescale (4 MHz oscillator input drives PLL directly)
    PLLDIV = 2	// Divide by 2 (8 MHz oscillator input)
    PLLDIV = 3	// Divide by 3 (12 MHz oscillator input)
    PLLDIV = 4	// Divide by 4 (16 MHz oscillator input)
    PLLDIV = 5	// Divide by 5 (20 MHz oscillator input)
    PLLDIV = 6	// Divide by 6 (24 MHz oscillator input)
    PLLDIV = 10	// Divide by 10 (40 MHz oscillator input)
    PLLDIV = 12	// Divide by 12 (48 MHz oscillator input)
    // CPU System Clock Postscaler:
    CPUDIV = OSC1_PLL2	// [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    CPUDIV = OSC2_PLL3	// [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    CPUDIV = OSC3_PLL4	// [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    CPUDIV = OSC4_PLL6	// [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    // USB Clock Selection bit (used in Full Speed USB mode only; UCFG:FSEN = 1):
    USBDIV = 1	// USB clock source comes directly from the primary oscillator block with no postscale
    USBDIV = 2	// USB clock source comes from the 96 MHz PLL divided by 2
    // Oscillator Selection bits:
    FOSC = XT_XT		// XT oscillator, XT used by USB
    FOSC = XTPLL_XT	// XT oscillator, PLL enabled, XT used by USB
    FOSC = ECIO_EC	// External clock, port function on RA6, EC used by USB
    FOSC = EC_EC		// External clock, CLKOUT on RA6, EC used by USB
    FOSC = ECPLLIO_EC	// External clock, PLL enabled, port function on RA6, EC used by USB
    FOSC = ECPLL_EC	// External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    FOSC = INTOSCIO_EC	// Internal oscillator, port function on RA6, EC used by USB
    FOSC = INTOSC_EC	// Internal oscillator, CLKOUT on RA6, EC used by USB
    FOSC = INTOSC_XT	// Internal oscillator, XT used by USB
    FOSC = INTOSC_HS	// Internal oscillator, HS used by USB
    FOSC = HS		// HS oscillator, HS used by USB
    FOSC = HSPLL_HS	// HS oscillator, PLL enabled, HS used by USB
    I have two matters to consider:
    1) I will use a 20MHz crystal for external oscillator.
    2) I will use USB feature of the PIC
    I read the datasheet of the PIC which says (at page 32) that for the case of using a 20MHz crystal these are the settings which I have to choose:
    1) PLL Division (PLLDIV2:PLLDV0): +5 (100)
    2) Clock Mode (FOSC3:FOSC0): HSPLL, ECPLL, ECPIO
    3) MCU Clock Division (CPUDIV1:CPUDIV0): +4 (10)
    I'm totally lost!
    The PIC datasheet and MPLAB help file are talking in different languages.
    I know I must add some "#pragma config xxx=yyy" lines at the beginning of my code, but I don't know what to add. The thing I want to learn most is what the CPUDIV value mean; what does "[OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]" mean? I googled for an hour and couldn't find any relevant result. Can anyone please help me add the required "pragma" lines in my code?
  2. #2
    Advanced Member level 5
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Re: PIC18F2550, C18 - What setting to choose for CPUDIV?
    Cannot help you directly with the C code, but have a look at this link to Microchips USB section - see the Software section for the USB Framework which might show you some code / config examples to work with.
    http://www.microchip.com/stellent/id...GE&nodeId=1486
    1 members found this post helpful.
  3. #3
    Full Member level 5
    Points: 2,729, Level: 12
    Join Date
    Jun 2008
    Egypt/Canada
    Posts
    246
    Points
    2,729
    Level
    12
    since you are using a 20 MHz crystal then you will need to pre-PLL divide by 5 to become 4MHz then the PLL will get it to 96 MHz, for USB it will be divided by 2 to get 48 MHz needed for USB.
    I think you should use
    however i think the CPU clocking is separate from the USB clocking system i.e. I don't think both of them must be at the same clock, they can be different, at least you can make both work on the same frequency, so use this:
    good luck
  4. #4
    Full Member level 5
    Points: 3,185, Level: 13
    Join Date
    Feb 2007
    USA
    Posts
    260
    Points
    3,185
    Level
    13
    Elrayes is correct, these are the settings you need for the USB.
    PLLDIV = 5 //20MHz / 5 = 4 MHz, input for the 96 MHz PLL
    CPUDIV = OSC1_PLL2 //CPU Clock = 96 MHz/2 = 48 MHz
    USBDIV = 2 //96MHz PLL/2 = 48 MHz for USB clock
    FOSC = HSPLL_HS //Osc type: High Speed Crystal/Resonator with PLL enabled
    VREGEN = ON //USB Internal Voltage Regulator enabled
    The above settings works for me when using 20 MHz XTAL.
    •   Alt20th October 2009, 17:29
      advertising
  5. #5
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    I modified my code just as you suggested me to do. But still my circuit does not work. Here is my new code:
    #include <p18f2550.h>
    #include <delays.h>
    #pragma config PLLDIV	= 5			// need 5 for 20MHz xtal
    #pragma config CPUDIV	= OSC1_PLL2	// CPU Clock = 96 MHz/2 = 48 MHz
    #pragma config USBDIV	= 2			// 96MHz PLL/2 = 48 MHz for USB clock
    #pragma config FOSC		= HSPLL_HS	// High Speed Crystal / Resonator with PLL enabled
    #pragma config WDT		= OFF		// no watchdog
    #pragma config LVP		= OFF		// LVP MUST be off
    #pragma config BOR		= OFF		// no brown out reset
    #pragma config MCLRE	= ON		// MCLR in use (so 10k to +5v essential)
    #pragma config PWRT		= ON		// power up timer on
    #pragma config PBADEN	= OFF		// disable PORTB a/d converter
    #pragma config VREGEN	= ON		// USB Internal Voltage Regulator enabled
    void main (void)
    	TRISB = 0;
    	PORTB = 0;
    	while (1)
    		PORTB = 0;
    		Delay10KTCYx(0);
    		PORTB = 0xFF;
    And this is my circuit:
    Is there any mistake in my design?
  6. #6
    Super Moderator
    Points: 69,588, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,377
    Points
    69,588
    Level
    64
    Cough cough.....
    With a layout like that it's a wonder anything works at all.
    You MUST place capacitors across the supply lines as close to the IC as possible and you MUST ensure the ground connection to the IC is as low impedance as possible to the ground side of the crystal loading capacitors.
    You oscillator could be on any frequency at the moment and there will be so much noise on the supply it is very unlikely it will be stable enough to run reliably if at all.
    Brian.
    •   Alt23rd October 2009, 09:13
      advertising
  7. #7
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    Quote Originally Posted by betwixt
    Cough cough.....
    Brian.
    Thank you for the advice.
    I designed a smaller circuit, with capacitors close to PIC. Checked for signals at the pin connections of the PIC and didn't see so much of noise to disturb the operation of PIC. I have to make clear that I successfully made this very same circuit work with assembly, and now it doesn't work with C code.
    I also check signals at two pins of crystal and there is no clock pulse there. In my previous circuit (the working one programmed with assembly language) had clock pulses at the crystal pins. Therefore, I think that the oscillator circuit of my PIC is not working. I changed the crystal and capacitors but it is still the same.
    Can anyone tell me if I have anything wrong with my code which I added in my previous message?
    Thanks in advance.
  8. #8
    Advanced Member level 1
    Points: 4,316, Level: 15
    Achievements:
    7 years registered
    anandpv2009's Avatar
    Join Date
    Aug 2009
    God's Own Country, Kerala
    Posts
    407
    Points
    4,316
    Level
    15
    Here is the HEX file that works fine with PIC18F2550 with 20mhz (xtal)...
    This code will on and off led connected to port B.
    I were tested it and it works fine...
    •   Alt23rd October 2009, 20:14
      advertising
  9. #9
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    Quote Originally Posted by anandpv2009
    Thank you, but your zip file contains only a hex file.
    I don't want to flash a led.
    I want to learn how to flash a led.
    I need a C18 source code, or someone to tell me what is wrong with my code...
  10. #10
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,377
    Points
    69,588
    Level
    64
    I doubt this is the problem but try using LATB instead of PORTB when you output the data.
    Brian.
  11. #11
    Achievements:
    7 years registered
    Join Date
    Aug 2009
    Posts
    407
    Points
    4,316
    Level
    15
    #include <18F2550.h>
    #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
    #use delay(clock=20000000)
    void main()
    set_tris_b(0);
    while(1)
    	output_b(0xff);
    delay_ms(100);
    	output_b(0x00);
    delay_ms(100);
    Why you are searching this simple code.....
    This is for CCS compile..
    I think your next switch on will be a success
    ha..am i correct
    [/img]
  12. #12
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    Didn't changed anything...
    #include <P18F2550.h>
    #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN	// LINE #34
    void main()
    set_tris_b(0);
    while(1)
    	output_b(0xff);
    delay_ms(100);
    	output_b(0x00);
    delay_ms(100);
    ha..am i correct
    Error given:
    Debug build of project `C:\Development\PIC\Projects\18F2550 Hello World\Project.mcp' started.
    Language tool versions: MPASMWIN.exe v5.34, mplink.exe v4.34, mcc18.exe v3.34
    Preprocessor symbol `__DEBUG' is defined.
    Sat Oct 24 14:06:43 2009
    Clean: Deleting intermediary and output files.
    Clean: Done.
    Executing: "C:\Development\PIC\MPLAB C18\bin\mcc18.exe" -p=18F2550 /i"C:\Development\PIC\MPLAB C18\h" "main.c" -fo="C:\Documents and Settings\<profilename>\Desktop\main.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
    C:\Development\PIC\Projects\18F2550 Hello World\main.c:34:Error: syntax error
    Halting build on first failure as requested.
    Debug build of project `C:\Development\PIC\Projects\18F2550 Hello World\Project.mcp' failed.
    BUILD FAILED
  13. #13
    Achievements:
    7 years registered
    Join Date
    Aug 2009
    Posts
    407
    Points
    4,316
    Level
    15
    You should use CCS compiler to work the above program...
    Please specify your compiler name.? I think your compiler is not CCS.
    You can download free version of ccs from net.
    One more thing, Whats about my previously posted hex (worked or not).?
  14. #14
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    IDE: MPLAB 8.40 Academic Version
    Compiler: MPLAB C18 3.34 Academic Version
    Your hex file works wonderful.
    I don't want to change my compiler. I can't find enough documentation and tutorial even for most popular compilers.
    I don't think things will be any better if I switch to CCS.
    Thank you anyway.
  15. #15
    Newbie level 5
    Points: 583, Level: 5
    Join Date
    Nov 2009
    UK
    Posts
    8
    Points
    583
    Level
    Dear hkBattousai
    Did you get your program to work? I am also having the same problem except that I am able to switch on the leds on porta, but I cannot manage to flash them.
  16. #16
    Achievements:
    7 years registered
    Join Date
    Aug 2009
    Posts
    407
    Points
    4,316
    Level
    15
    I need more details about your problems to help you (if i can)....
  17. #17
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    I made it work, thank you for your concern.
    Here is a working blink-a-led example:
    #include "delays.h"
    #pragma config DEBUG	= OFF
    void blinkLed(unsigned char led);
    void main (void)
    	ADCON0=0x00;
    	ADCON1=0x0f;
    	CMCON=7;
    	TRISAbits.TRISA0 = 0;
    	TRISAbits.TRISA1 = 0;
    	TRISAbits.TRISA2 = 0;
    	TRISAbits.TRISA3 = 0;
    	TRISAbits.TRISA4 = 0;
    	LATAbits.LATA0 = 0;
    	LATAbits.LATA1 = 0;
    	LATAbits.LATA2 = 0;
    	LATAbits.LATA3 = 0;
    	LATAbits.LATA4 = 0;
    	blinkLed(0);
    	blinkLed(1);
    	blinkLed(2);
    	blinkLed(3);
    	blinkLed(4);
    	while(1);
    	int j; for (j=0; j<10; j++)
    		switch (led)
    			case 0:
    				LATAbits.LATA0 = 1;
    				Delay10KTCYx(0);
    				LATAbits.LATA0 = 0;
    				Delay10KTCYx(0);
    				break;
    			case 1:
    				LATAbits.LATA1 = 1;
    				Delay10KTCYx(0);
    				LATAbits.LATA1 = 0;
    				Delay10KTCYx(0);
    				break;
    			case 2:
    				LATAbits.LATA2 = 1;
    				Delay10KTCYx(0);
    				LATAbits.LATA2 = 0;
    				Delay10KTCYx(0);
    				break;
    			case 3:
    				LATAbits.LATA3 = 1;
    				Delay10KTCYx(0);
    				LATAbits.LATA3 = 0;
    				Delay10KTCYx(0);
    				break;
    			case 4:
    				LATAbits.LATA4 = 1;
    				Delay10KTCYx(0);
    				LATAbits.LATA4 = 0;
    				Delay10KTCYx(0);
    				break;
    			default:
    				LATAbits.LATA0 = 0;
    				LATAbits.LATA1 = 0;
    				LATAbits.LATA2 = 0;
    				LATAbits.LATA3 = 0;
    				LATAbits.LATA4 = 0;
    				break;
  18. #18
    Newbie level 5
    Join Date
    Nov 2009
    UK
    Posts
    8
    Points
    583
    Level
    I have a problem with configuring the external oscillator. The program i have written only switches the led, it supposed to be flashing.
    #include <p18f4550.h>
    #include <delays.h>
    //----Interrupt toggle prototype------------------------
    void led_toggle (void);
    // -------High priority interrupt vector-----------------
    #pragma code InterruptVectorHigh = 0x08
    void InterruptVectorHigh (void) {
    _asm
    goto led_toggle //jump to interrupt routine
    _endasm
    // -----------High priority interrupt routine---------------
    #pragma code
    #pragma interrupt led_toggle
    void led_toggle () {
    if (INTCONbits.TMR0IF) { //check for TMR0 overflow
    LATAbits.LATA0 = ~LATAbits.LATA0;
    // PORTA = 0x00;
    TMR0L = 0x00;
    INTCON = 0x20; // Set T0IE, clear T0IF
    //-------Main code-------------------------------------------------
    #pragma code
    void main (void)
    /* Configure output pin for LED */
    TRISA = 0xFC; //two LSB configured to be output
    LATA = 0x00;
    //Initialise Timer0 and its interrupt */
    INTCON = 0x20; // disable global and enable timer interrupt
    INTCON2 = 0x84; // TMR0 high priority
    RCONbits.IPEN = 1; // enable priority levels
    TMR0H = 0x00; // clear timer
    TMR0L = 0x00; // clear timer
    T0CON = 0xc5; // set up timer0, 16-bit, 1:64 prescaler
    INTCONbits.GIEH = 1; // enable interrupts
    while (1)
  19. #19
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Turkey
    Posts
    118
    Points
    2,472
    Level
    11
    ^ I don't know much about PIC interrupts, but it looks like your interrupt is running only once. I don't think you have an oscillator configuration problem. If you insist that you have a configuration problem then, I suggest, try running something simpler; comment out all those interrupt part of your code and copy/paste my blink-a-led example above. If it works then your code indeed has an interrupt calling problem, not something related to configuration.
  20. #20
    Newbie level 5
    Join Date
    Nov 2009
    UK
    Posts
    8
    Points
    583
    Level
    ^I have tried your program and it works as expected.
    I am able to flash one led with my program (refer my previous post) with FOSC = INTOSC_HS. I dont know why I cant with FOSC = HSPLL_HS.
    •   Alt14th November 2009, 21:33
      advertising
