+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 6
    Points: 922, Level: 6
    Join Date
    Sep 2009
    singapore
    Posts
    14
    Points
    922
    Level
    what is the difference between ARM and PIC processor?
    as title.
    Thank you ~
    •   Alt8th October 2009, 08:43
      advertising
  2. #2
    Points: 14,157, Level: 28
    Join Date
    Jun 2005
    Stanford, SF Bay Peninsula, California, Earth, Solar System, Milky Way
    Posts
    1,418
    Points
    14,157
    Level
    28
    Re: what is the difference between ARM and PIC processor?
    Below is a list. I have compiled it in December 2008. Obviously, it's not a complete list, and it's merely a single opinion.
    Pros and Cons of ARMs (compared to PIC18)
    Pro:
    Ample resources (ROM, RAM)
    Faster program execution.
    More sophisticated interrupt architecture
    Exceptions
    C++ compilers, which might speed-up development and facilitate code reuse
    JTAG
    Many silicon vendors
    Many flavors
    Con:
    Smaller mind share
    Lack of small device (the smallest one is 48-QFP)
    Larger amount of necessary external hardware
    •   Alt9th October 2009, 20:30
      advertising
  3. #3
    Newbie level 1
    Points: 1,077, Level: 7
    Join Date
    Dec 2006
    Posts
    Points
    1,077
    Level
    7
    Comparing a 32 bits ARM with an 8 bits PIC18 is like comparing a bicycle with a truck...
    A fair comparison is comparing an ARM with a PIC32.
    Actually there is a benchmark done by an independant source called coremark.
    Just select NXP (Cortex M3 core) & Microchip :
    http://www.coremark.org/benchmark/in...p?pg=benchmark
    You'll see that the result is that the 80MHz PIC32 scores higher than the 100MHz NXP device...
    If you want to get started : http://www.microchip.com/PIC32
    regards
