+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Newbie level 6
    Points: 1,154, Level: 7
    Join Date
    Jan 2009
    Posts
    14
    Points
    1,154
    Level
    7
    Where is Gerber Tool in Cadence 16.2?
    I usually use Gerber tool for process gerber files created from Orcad Layout (using Tearsdrop, save Gerber file as a lower version).
    I can find it in Orcad 16.0 but when I try Cadence 16.2, I can't find Gerber Tool.
    Do you know where it is? Or there is a replacement for it?
    Would you please show me?
    Thanks in advance!
  2. #2
    Member level 4
    Points: 1,899, Level: 10
    Join Date
    Jun 2008
    Posts
    69
    Points
    1,899
    Level
    10
    Re: Where is Gerber Tool in Cadence 16.2?
    Goto Tools Art work tab.From that u can create the gerber files
    Regards
    Rajan.K
  3. #3
    Newbie level 6
    Join Date
    Jan 2009
    Posts
    14
    Points
    1,154
    Level
    7
    Sorry, but can you tell me more clearly? Where is the "Tools Art work tab" that you mean? I can't find it.
    Thanks.
    •   Alt8th October 2009, 10:38
      advertising
  4. #4
    Full Member level 2
    Points: 3,324, Level: 13
    TraceRouter's Avatar
    Join Date
    Aug 2005
    Wichita, KS
    Posts
    141
    Points
    3,324
    Level
    13
    Go to the Manufacture menu and select select Artwork
  5. #5
    Newbie level 6
    Join Date
    Jan 2009
    Posts
    14
    Points
    1,154
    Level
    7
    I tried but can not access .gtd files :(
  6. #6
    Newbie level 3
    Points: 395, Level: 4
    Join Date
    Oct 2010
    Posts
    Points
    395
    Level
    There is no such special interface ....To open Gerber (.Art) files you need to create a new package symbol import artwortk and you are done .............Better use dedicated viewers ......Gerber view or the like............... and any one could please tell me ho to auto route with jumper in orcad pcb editor 16.3
    •   Alt31st October 2010, 11:07
      advertising
  7. #7
    Member level 4
    Points: 1,735, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jan 2010
    Posts
    78
    Points
    1,735
    Level
    9
    hi
    use CAM350 or AltiumDesigner to view gerber. or to run tear drop , pad removal etc
    SA
  8. #8
    Newbie level 6
    Points: 757, Level: 6
    Join Date
    Oct 2010
    Posts
    11
    Points
    757
    Level
    go to manufacture>>>>artwork
  9. #9
    Newbie level 3
    Join Date
    Oct 2010
    Posts
    Points
    395
    Level
    File > New
    in the window that follows select package and name it; ok to terminate
    Open > Import > Artwork and locate your artwork in working Dir> Allegro and place it ................you are done.....................Better use dedicated viewers . Allegro downloads provides supporting softwares
  10. #10
    Newbie level 1
    Points: 384, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    384
    Level
    Quote Originally Posted by pirate303 View Post
    File > New
    There is no true GerbTool in Cadence 16.2 or 16.3.
    GerbTool by Wise was included in Orcad layout which is no longer supported.
    To use GerbTool you have to open Orcad layout software rev. 16.0 or lower to access GerbTool under the tools menus.
  11. #11
    Junior Member level 3
    Points: 1,036, Level: 7
    mashak's Avatar
    Join Date
    Dec 2007
    Posts
    28
    Points
    1,036
    Level
    7
    Use Pentalogix Viewmate to view the .Art files. You can downlad the freen version form Pantalogix.com.
    •   Alt9th November 2010, 15:06
      advertising
  12. #12
    Newbie level 3
    Join Date
    Oct 2010
    Posts
    Points
    395
    Level
    Quote Originally Posted by Carveyr View Post
    That's what I have stated first ..............and the rest is a simple solution for viewing it from within Allegro.....You got me...............
  13. #13
    Newbie level 6
    Points: 542, Level: 4
    Join Date
    Mar 2010
    Philippines
    Posts
    11
    Points
    542
    Level
    just use a dedicated Gerber viewer.
