+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 5
    Points: 935, Level: 6
    Join Date
    May 2008
    Posts
    10
    Points
    935
    Level
    Flyback converter feedback isolation with opto-coupler
    I'm building a voltage feedback flyback converter to turn a 12v input into a 24v output at 1Amp. I've successfully simulated and built this circuit on breadboard without isolation. Now I'm adding isolation. A tranformer in the forward path and an opto-coupler in the feedback path, but I'm having major headaches with the opto-coupler.
    I've never used optos before and hence I'm a little lost. I'm just trying to put an opto in feedback path for isolation, keeping my compensation network on the primary side. So far I got whats in the attached image. This works great but obviously there is no isolation in the feedback network. I tried putting an opto-coupler in many configurations but it never transmits the voltage level properly causing the SMPS output to rise to about 70v instead of settling at 24v.
    Can somebody please help me out with figuring out how to correctly use this optocoupler.
    Thanks,
    -Igs
    •   Alt7th October 2009, 11:33
      advertising
  2. #2
    Super Moderator
    Points: 241,537, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,932
    Points
    241,537
    Level
    100
    There are tons of applications circuits with isolated voltage feedback. Most use a TL431 as voltage reference on the secondary.
    •   Alt7th October 2009, 15:54
      advertising
  3. #3
    Junior Member level 1
    Points: 488, Level: 4
    Join Date
    Mar 2011
    Posts
    19
    Points
    488
    Level
    Re: Flyback converter feedback isolation with opto-coupler
    sorry..what flyback transformer used in this converter?
    •   Alt17th March 2011, 14:22
      advertising
  4. #4
    Advanced Member level 3
    Points: 6,508, Level: 19
    Join Date
    Jun 2009
    New Zealand
    Posts
    800
    Points
    6,508
    Level
    19
    Possibly a linear opto coupler circuit (IL200, IL300 series) to give you a re-creation of the o/p volts on the pri saide that you can use for regulation.
    Regards, Orson Cart.
  5. #5
    Advanced Member level 1
    Points: 5,273, Level: 17
    grittinjames's Avatar
    Join Date
    Jun 2006
    bangalore india
    Posts
    480
    Points
    5,273
    Level
    17
    817 Opto will do?
    •   Alt22nd March 2011, 23:34
      advertising
  6. #6
    Join Date
    Jun 2009
    New Zealand
    Posts
    800
    Points
    6,508
    Level
    19
    Nope - not if you want the regulation circuitry on the primary side.
