+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 1
    Points: 580, Level: 5
    Join Date
    Sep 2009
    Posts
    Points
    580
    Level
    Interfacing 8051 with infrared or blutooth
    Hi guys,
    m working on a project called bus schedule indicator. in dis proj i need 2 identify d buses cuming on a particular stop. i hv 2 options for wireless data transfer i.e. bluetooth and infrared. i want 2 interface either bluetooth or infrared receiver wid microcontroller 8051 which in turn will b interfaced wid a gsm modem which ll send a msg about d bus no 2 another gsm modem at d server. which option will b better both economically n practically? n also dis is my very 1st proj in embedded systems so it will b gr8 if sum1 cld provide me wid a proper guide bout bluetooth,infrared n interfacing. thnx a lot.
    •   Alt20th September 2009, 12:55
      advertising
  2. #2
    Member level 1
    Points: 748, Level: 5
    Join Date
    Sep 2009
    Johore, Malaysia
    Posts
    35
    Points
    748
    Level
    please use proper english words, sir. reading thru your message gives me headache. sorry if you are offended.
    •   Alt20th September 2009, 13:25
      advertising
  3. #3
    Newbie level 1
    Join Date
    Sep 2009
    Posts
    Points
    580
    Level
    Sorry for the inconvenience.. Reiterating myself in proper english..
    Hi guys,
    I am working on a project called bus schedule indicator. In this project i need to identify the buses coming at a particular stop. I have 2 options for wireless data transfer i.e. bluetooth and infrared. I want to interface either bluetooth or infrared receiver with microcontroller 8051 which in turn will be interfaced with a GSM modem which will send a msg about the bus no to another GSM modem at the server. Which option will be better both economically n practically? And also this is my very 1st project in embedded systems so it will b great if someone could provide me with a proper guide about bluetooth,infrared n interfacing. Thanks a lot.
    •   Alt20th September 2009, 13:31
      advertising
  4. #4
    Advanced Member level 5
    Points: 13,542, Level: 27
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,960
    Points
    13,542
    Level
    27
    Blog Entries
    18
    Infra red will be easier and cheaper
    Nandhu
    (still you use short hand)
  5. #5
    Full Member level 3
    Points: 1,940, Level: 10
    Join Date
    Dec 2008
    12°52′N 74°53′E
    Posts
    179
    Points
    1,940
    Level
    10
    Re: Interfacing 8051 with infrared or blutooth
    By examining your description, I think even if bluetooth is costlier, and complex to interface, it is a better choice because you need proper positioning of transmitter and receiver in the case of infrared which is difficult to achieve because you cannot park a bus with that precision.
    Hope my suggestion helps.
    :D
    •   Alt24th September 2009, 12:19
      advertising
  6. #6
    Junior Member level 1
    Points: 606, Level: 5
    Join Date
    Jan 2010
    UK
    Posts
    19
    Points
    606
    Level
    I use BLUEMORE200 module from www.eikonsite.it that is very easy to setup and works fine as transparent UART
    hope this info helps you in your project
