vlsi mini projects based on fpga design using hdl verilog
ian77316
SDRAM controller
My boss gave me a job is to design a SDRAM controller.
The SDRAM is produced by the Hitachi and the model is " hm5216165".
I already design it according to the datasheet .
However, I encountered a big problem.
I can use the mode of "single write/single read",but when I ues the mode of "Burst write/Burst read" ,the problem will occure.
The problem is that when I use "Burst write/Burst read" the address of SDRAM will not change.
For examle,when I write 4 data("1","2","3","4") and read 4 data from SDRAM,but the result of read out data is ("1","1","1","1").
I have only read the first data and read the same data.
I checked many times but still could not find any problems.
This problem has been confused me for a long time.
Do not know if there is no one encountered this kind of problem.
Hope someone can help me solve it. thx....
Re: SDRAM controller
Can u please post the code. and datasheet of the sdram
My SDRAM controller is set at 30 MHz and latency=1 clock.
I use the verilog.
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 20:21:49 09/03/2009
// Design Name:
// Module Name: sd_ctrl
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module sd_ctrl(clk,rst,address,RAS,CAS,WE,CS,CKE,A,DQM,read,write,mode,host_data,ready,D,sdread_data);
input clk,rst;
//to sdram
output RAS,CAS,WE,CS,CKE;
output [11:0]A;
output [1:0]DQM;
//from host
input read,write;
input [2:0]mode;
input [19:0]address;
input [15:0]host_data;
output ready;
output [15:0]sdread_data;
//inout
inout [15:0]D;
//element
reg RAS,CAS,WE,CS,CKE;
reg [11:0]A;
reg [1:0]DQM;
reg ready;
wire [15:0]D;
reg [13:0]counter;
reg [19:0]autorefresh_counter;//auto refresh counter
reg zero;
reg [15:0]sdread_data;
reg [11:0]addr_A;
reg [9:0]mode_A;
reg enrefresh,en_autorefresh_counter;
reg do_write,down_write;
reg en_write;
reg en_read;
reg row,col;
reg [4:0]state;
reg [4:0]next;
//inout line
assign D=en_write?host_data:16'hzzzz;
//parameter
parameter power_on=5'd0;
parameter precharge_all=5'd1;
parameter trp1=5'd2;
parameter mrs=5'd3;
parameter autorefresh1=5'd4;
parameter autorefresh_nop1=5'd5;
parameter autorefresh2=5'd6;
parameter autorefresh_nop2=5'd7;
parameter idle=5'd8;
parameter active=5'd9;
parameter trcd1=5'd10;
parameter fsm_write1=5'd11;
parameter fsm_write2=5'd12;
parameter fsm_write3=5'd13;
parameter fsm_write4=5'd14;
parameter tdal1=5'd15;
parameter tdal2=5'd16;
parameter fsm_read=5'd17;
parameter read_data1=5'd18;
parameter read_data2=5'd19;
parameter read_data3=5'd20;
parameter read_data4=5'd21;
parameter autoprecharge1=5'd22;
parameter aautorefresh1=5'd23;
parameter aautorefresh_nop1=5'd24;
parameter aautorefresh2=5'd25;
parameter aautorefresh_nop2=5'd26;
always @ *//data & address form host to sdram controller
begin
addr_A[11]=address[19];// select bank
case({row,col})
2'b10:addr_A[10:0]=address[18:8];
2'b01:addr_A[10:0]={3'b000,address[7:0]};
default:addr_A[10:0]=11'd0;
endcase
end
always @ *//mode
begin
case(mode)
3'b000:mode_A=10'b1_00_001_0_000;//1
3'b001:mode_A=10'b0_00_001_0_001;//2
3'b010:mode_A=10'b0_00_001_0_010;//4
3'b011:mode_A=10'b0_00_001_0_011;//8
3'b100:mode_A=10'b0_00_001_0_111;//full page
default:mode_A=10'b1_00_001_0_000;//1
endcase
end
always @ (posedge clk)//do_write data control
begin
if(write)
do_write<=1'b1;
else if(down_write)
do_write<=1'b0;
end
always @(posedge clk)// read data from sdram to sdramcrl
begin
if(en_read)
sdread_data<=D;
end
always @(posedge clk)//counter
begin
if(zero)
counter<=14'd0;
else if(rst)
counter<=14'd0;
else
counter<=counter+14'd1;
end
always @ (posedge clk)//autorefresh_counter
begin
if(en_autorefresh_counter)
autorefresh_counter<=autorefresh_counter+20'd1;
else
autorefresh_counter<=20'd0;
end
always @ *//control autorefresh
begin
if(autorefresh_counter[19:0]==20'b11101010011001100000) //32ms do auto refresh
enrefresh<=1'b1;
else
enrefresh<=1'b0;
end
always @ (posedge clk)//fsm
begin
if(rst)
state <= power_on;
else
state <= next;
end
always@*//fsm
begin
//sdram device deselect
CKE=1'b1;
CS=1'b1;
RAS=1'bx;
CAS=1'bx;
WE=1'bx;
A[11]=1'bx;
A[10]=1'bx;
A[9:0]=addr_A[10:0];
DQM=2'b00;
//control line
ready=1'b0;
zero=1'b1;
en_autorefresh_counter=1'b0;
en_write=1'b0;
down_write=1'b0;
en_read=1'b0;
row=1'b0;
col=1'b0;
case(state)
power_on:
begin
DQM=2'b11;
zero=1'b0;
begin
if(counter==14'd6000)//wait 200us
next=precharge_all;
else
next=power_on;
end
end
precharge_all:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b1;
WE=1'b0;
A[11]=1'bx;
A[10]=1'b1;
A[9:0]=10'bxxxxx_xxxxx;
DQM=2'b11;
next=trp1;
end
trp1://min 30ns
begin
DQM=2'b11;
next=autorefresh1;
end
autorefresh1:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b0;
WE=1'b1;
A[11]=1'bx;
A[10]=1'bx;
DQM=2'b11;
next=autorefresh_nop1;
end
autorefresh_nop1://trc min 90
begin
DQM=2'b11;
zero=1'b0;
begin
if(counter==14'd2)
next=autorefresh2;
else
end
end
autorefresh2:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b0;
WE=1'b1;
A[11]=1'bx;
A[10]=1'bx;
DQM=2'b11;
next=autorefresh_nop2;
end
autorefresh_nop2://trc min 90
begin
DQM=2'b11;
zero=1'b0;
begin
if(counter==14'd2)
next=mrs;
else
end
end
mrs:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b0;
WE=1'b0;
A[11]=1'b0;
A[10]=1'b0;
A[9:0]=mode_A;
DQM=2'b11;
next=idle;
end
idle:
begin
CKE=1'b1;
CS=1'b0;
DQM=2'b00;
en_autorefresh_counter=1'b1;
ready=1'b1;
case({enrefresh,read,write})
3'b100:next=aautorefresh1;
3'b101:next=aautorefresh1;
3'b110:next=aautorefresh1;
3'b111:next=aautorefresh1;
3'b000:next=idle;
3'b011:next=idle;
3'b001:next=active;
3'b010:next=active;
default:next=idle;
endcase
end
active://do row precharge
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b1;
WE=1'b1;
A[11]=addr_A[11];//active bank A
A[10]=addr_A[10];
A[9:0]=addr_A[9:0];
DQM=2'b00;
row=1'b1;
next=trcd1;
end
trcd1://trcd min 30
begin
DQM=2'b00;
begin
if(do_write)
next=fsm_write1;
else
next=fsm_read;
end
end
fsm_write1://write cmd in & write data
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b1;
CAS=1'b0;
WE=1'b0;
A[11]=addr_A[11];//write in bank A
A[10]=1'b1;
A[9:0]=addr_A[9:0];
DQM=2'b00;
en_write=1'b1;
down_write=1'b1;
col=1'b1;
next=fsm_write2;
end
fsm_write2://nop
begin
DQM=2'b00;
en_write=1'b1;
next=fsm_write3;
end
fsm_write3://nop
begin
DQM=2'b00;
en_write=1'b1;
next=fsm_write4;
end
fsm_write4://nop
begin
DQM=2'b00;
en_write=1'b1;
next=tdal1;
end
tdal1://twr
begin
DQM=2'b00;
next=tdal2;
end
tdal2://trp
begin
DQM=2'b00;
next=idle;
end
fsm_read://read cmd in
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b1;
CAS=1'b0;
WE=1'b1;
A[11]=addr_A[11];//read from bank A
A[10]=1'b1;
A[9:0]=addr_A[9:0];
DQM=2'b00;
en_read=1'b1;
col=1'b1;
next=read_data1;
end
read_data1://latency=1
begin
DQM=2'b00;
en_read=1'b1;
next=read_data2;
end
read_data2:
begin
DQM=2'b00;
en_read=1'b1;
next=read_data3;
end
read_data3:
begin
DQM=2'b00;
en_read=1'b1;
next=read_data4;
end
read_data4:
begin
DQM=2'b00;
next=autoprecharge1;
end
autoprecharge1: //trp min is 30 , do autoprecharge
begin
DQM=2'b00;
next=idle;
end
aautorefresh1:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b0;
WE=1'b1;
A[11]=1'bx;
A[10]=1'bx;
DQM=2'b11;
next=aautorefresh_nop1;
end
aautorefresh_nop1://trc min 90
begin
DQM=2'b11;
zero=1'b0;
begin
if(counter==14'd2)
next=aautorefresh2;
else
end
end
aautorefresh2:
begin
CKE=1'b1;
CS=1'b0;
RAS=1'b0;
CAS=1'b0;
WE=1'b1;
A[11]=1'bx;
A[10]=1'bx;
DQM=2'b11;
next=aautorefresh_nop2;
end
aautorefresh_nop2://trc min 90
begin
DQM=2'b11;
zero=1'b0;
begin
if(counter==14'd2)
next=idle;
else
end
end
endcase
end
endmodule
Hope expert can provide advice to tell where I may be wrong.
thx.....
SDRAM controller
hi,T think you may try use the refdesign from altera。It is quite easyto understand and powerful
SDRAM controller
it seems like you've kept your CAS always asserted thru the burst read and write... i'd suggest you de-assert cas after fsm_read and fsm_write1.
Try asserting and deasserting cas whenever it reads from the SDRAM. that should work.
Added after 38 seconds:
is the burst write working properly?
Hi leonqin,
thanks for your suggestion but my boss asked me use Xilinx.
Hi mytechface,
do you mean that CAS should be "low" when read and write?
And the other time it should be "high"?
Hi sudhirkv,
so you mean that I shoude not use "CAS=1'bx"??
I should give CAS=1'b1 or CAS=1'b0??
sorry,I am sure that SDRAM controller sent four data to SDRAM properly,but i am not sure that if the SDRAM save data properly.
Yes try with cas low when read or write. Before that please refer to the timing diagram of the attached document.
This datasheet is applicable for all sdram's.
Try address as data while checking for the sdram read and write.
Re: vlsi mini projects based on fpga design using hdl verilo
hi sudhirkv,
I have done as you say and also seen the datasheet but the result is wrong.
I still can not find why column address does not change.
What are the reasons can cause this problem?
thx.........
I want to clarify one thing from you,
what is the sdram u r using, if possible send me the data sheet of your sdram.
most of the cases there is no need to change the verilog code since it is already optimized. you need to check what configurations u have given in the verilog coding like row address column address burst rate like that.
How u r checking the CAS and R/W signal.
Have you tried address as data to the sdram. what is the result u got
Added after 1 hours 6 minutes:
sorry i didnt see the attached document on your previous post.
my suggestions
try using non blocking statement in all the always blocks .
other basic settings are ok. i cudnt see any issue on that. please check whether u r meeting the timing specified in the datasheet.
this should work if all the timings are OK.
Hi sudhirkv,
I first want to be properly grateful to u.I know this should work if all the timings are OK.
and I use modelsim and LA to find the error,but I cannot find any error.
however, when I take it to another block of sdram for testing,it will be the normal operation.
The original problem occurs because the sdram not me.
Thank you for spending so much time to help me debug!
very grateful to you!!!!!!!!!thx!!!!!
So you got the output when u changed the sdram. is that so?.
Great and all the best
