Transfering a part of a sheet to another sheet in Powerlogic
nzkunal
Member level 2
powerlogic sheet number
I want to copy some components from one sheet to another cut/paste doesnt work any ideaz
Re: Transfering a part of a sheet to another sheet in Powerl
Right click-->select anything, & select the things you need to copy,
right click-->save to file, Will be saved as .grp file.
Then Edit-->paste from file, select the .grp file you saved & paste it whereever you need.
If you use PowerLogic 5 or older. do not forget to set group origin before
saving it to .grp file!
Varuzhan
