+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 767, Level: 6
    Join Date
    Jun 2009
    Posts
    18
    Points
    767
    Level
    bmp to hex
    Hello,
    Can anybody help me in providing bmp to graphic lcd hex file converter for my
    240x128 lcd. I know there are no. of them freely available on the net but i was
    unable to found one.
    any help is welcome.
    •   Alt4th September 2009, 16:31
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    picture to graphic lcd c converter
    Have used this program - it works well, you can use ms paint to edit or create your bmp.
    http://www.piclist.com/techref/microchip/bmp2asm.htm
    •   Alt4th September 2009, 17:46
      advertising
  3. #3
    Full Member level 1
    Points: 2,396, Level: 11
    Achievements:
    7 years registered
    nishal's Avatar
    Join Date
    May 2007
    Posts
    108
    Points
    2,396
    Level
    11
    bmp hex
    A tool named 'Bitmap and Font Converter' is available inside the Microchip Graphic Library, With this you will be able to convert the bitmap image to '*.c' file to use in your project.
    Hope this helps!
    Nishal
    •   Alt5th September 2009, 10:52
      advertising
  4. #4
    Full Member level 2
    Points: 1,945, Level: 10
    Join Date
    Mar 2005
    Posts
    136
    Points
    1,945
    Level
    10
    Re: bmp to graphic lcd hex converter
    I WANT A LED DISPLAY HLP
  5. #5
    Full Member level 1
    Points: 2,608, Level: 11
    Achievements:
    7 years registered
    davemaster's Avatar
    Join Date
    Jan 2007
    Peru, South America
    Posts
    112
    Points
    2,608
    Level
    11
    Re: bmp to hex
    Quote Originally Posted by Tajinder Singh View Post
    Hello,
    gREETINGS,
    You can program by yourself (I use C# .NET) to convert your image into HEX values.
    I just attached one to this post.
    Good Luck BMP2HEX.rar
    1 members found this post helpful.
