+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Junior Member level 3
    Points: 1,868, Level: 10
    Achievements:
    7 years registered
    Feri4030's Avatar
    Join Date
    Feb 2009
    Persia
    Posts
    31
    Points
    1,868
    Level
    10
    floquet port hfss
    A guide to Floquet port in HFSS v11
    •   Alt3rd September 2009, 17:20
      advertising
  2. #2
    Junior Member level 2
    Points: 694, Level: 5
    Join Date
    Sep 2009
    Posts
    23
    Points
    694
    Level
    hfss floquet
    This is very useful for me. Thank you!
    1 members found this post helpful.
  3. #3
    Newbie level 2
    Points: 581, Level: 5
    Join Date
    Sep 2009
    asia
    Posts
    Points
    581
    Level
    hfss v11
    Could some one help me in understand how to plot the result of a single sell cell of an FSS structure simulated using floquet port as described in the above literature HFSSFloquet.pdf. I would like to know how to get the transmission and reflection coefficient. Also the S11.
    My first post here and am trying to learn the tool.
    Thanks a lot.
  4. #4
    Achievements:
    7 years registered
    Feri4030's Avatar
    Join Date
    Feb 2009
    Persia
    Posts
    31
    Points
    1,868
    Level
    10
    floquet port
    Quote Originally Posted by radio09
    Thanks a lot.
    Note that HFSS calculates generalized S-param which means that the reflection coefficient equals to S11 and transmission coefficient is equal to the S12.
    If you want to obtain conventional S-param (like those Network analyzer calculates) u should use some "post processing" to normalize the S-param to some impedance (say 50 ohm) or u can simply use the formula conversion from reflection coefficient to normalized S-param, these formulas can be found in many books like microwave engineering, Pozar
    2 members found this post helpful.
  5. #5
    Points: 751, Level: 6
    Join Date
    Jan 2011
    Posts
    24
    Points
    751
    Level
    Re: A guide to Floquet port in HFSS v11
    Quick note.
    For the version 11 release, the following restrictions apply:
    • Currently, only modal projects may contain Floquet ports.
    • Boundaries that are adjacent to a Floquet port must be linked boundaries.
    • Fast frequency sweep is not supported. (Discrete and interpolating sweep are supported.)
    Version 13 don't seem to have those limitations. Update and enjoy like me
    Joline.
  6. #6
    Newbie level 3
    Points: 449, Level: 4
    Join Date
    Jul 2010
    china
    Posts
    Points
    449
    Level
    thank you very much
  7. #7
    Newbie level 1
    Points: 246, Level: 2
    Join Date
    Aug 2011
    Posts
    Points
    246
    Level
    Re: floquet port hfss
    Quote Originally Posted by Feri4030 View Post
    Thanks, i really need it~
    •   Alt8th August 2011, 08:27
      advertising
  8. #8
    Member level 2
    Points: 610, Level: 5
    covcst's Avatar
    Join Date
    May 2011
    portugal
    Posts
    44
    Points
    610
    Level
    Thanks a lot....
  9. #9
    Junior Member level 1
    Points: 1,013, Level: 7
    Join Date
    Dec 2011
    Posts
    18
    Points
    1,013
    Level
    7
    helo,
    Is there any (pdf) about the excitation by an incident wave?
    thanks in advance
  10. #10
    Newbie level 5
    Points: 1,173, Level: 7
    Join Date
    Sep 2009
    Posts
    8
    Points
    1,173
    Level
    7
    Hi everyone,
    If I have an antenna that must be feed at the bottom of the air box (where the Floquet port should be positioned) how can I make a simulation in this mode?
    Thanks
  11. #11
    Points: 223, Level: 2
    Join Date
    Oct 2012
    Posts
    Points
    223
    Level
    Quote Originally Posted by cosmefulanito View Post
    Hi everyone,
    Thanks
    In my opinion, floquet port is also a kind of feed or excitation.the mode TE and TM should cover all the situation, I think. I wonder if my opinion is right.
  12. #12
    Full Member level 5
    Points: 1,704, Level: 9
    Join Date
    Dec 2011
    UK
    Posts
    275
    Points
    1,704
    Level
    9
    Re: floquet port
    The transmission coefficient from port 1 to port 2 is S21, not S12.
    •   Alt18th October 2012, 04:13
      advertising
  13. #13
    Achievements:
    7 years registered
    Feri4030's Avatar
    Join Date
    Feb 2009
    Persia
    Posts
    31
    Points
    1,868
    Level
    10
    Quote Originally Posted by friendchip View Post
    I agree with friendchip, but it should be noticed that Floquet port is matched in all frequencies, however, the feed is not. I think first you should make sure that the Floquet port (with specific settings) and the feed launch the same field pattern (i.e. same TE/TM modes) so these two will have the same matching condition. You can easily figure out which mode is excited by the feed (using the geometry of the feed and it's probably one of the fundamental modes) and configure the Floquet port to excite the same mode.
    Why don't you use the feed as excitation?
    Good Luck
  14. #14
    Points: 1,212, Level: 7
    strange007's Avatar
    Join Date
    Dec 2007
    Posts
    Points
    1,212
    Level
    7
    Thank you so much!
  15. #15
    Newbie level 6
    Points: 94, Level: 1
    Join Date
    Oct 2013
    Posts
    11
    Points
    94
    Level
    Very useful for me thank you for uploading it...........
