+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Newbie level 5
    Points: 819, Level: 6
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    at89s52 microcontroller
    Gentlemen and everybody,
    It is a really really very urgent!!!!!!!!! I know most of the people say this but I really need a solution very urgently. Its a very kind request.I am new to embedded systems so kindly explain in little details as u explain.
    This is a very simple project. I have to control 2 dc motors via serial interface from PC. Schematic and code attached. Points for consideration :-
    1. Serial interface is made using max232 and is tested in another boad and is working 100% fine.
    2. The rest of the circuit (except microcontroller) is working when i connect a 3v duracell battery in place of output port pins where i require 1's. The circuit works fine with 3v battery. I am using a SMPS with 24V, 2.5A rating in place of24V battery shown in the schematic, Relays work on 12V.
    3. The microcontroller is working fine as i have tested microcontroller in another board and LED's are glowing as desired.
    4. Now when i put microcontroller in my circuit. the circuit does not work. ??????
    5. Since the circuit is working with 3V battery then in should work with 3.5V at output pins of micrcontroller.But it is not working.
    6. Some of my friends suggested that there is a difference in the current level, I also think the same. but can u please suggest a way to switch ON BC547 from output pin of at89s52.
    I would be really really thankful..
    MOV TMOD,#00100000b
    MOV TH1,#253d
    MOV SCON,#01000000B
    SETB REN
    MOV PCON,#00h
    SETB TR1
    WAITLOOP:
            JBC RI,GETDATA
            SJMP WAITLOOP
    GETDATA:
            MOV A,SBUF
            MOV P2,A
            MOV SBUF,A
            WAITX:
                    JNB TI,WAITX
                    CLR TI
            SJMP WAITLOOP
    This programme is written using keil uvision.
    •   Alt31st August 2009, 11:27
      advertising
  2. #2
    Newbie level 6
    Points: 663, Level: 5
    Join Date
    Aug 2009
    Pakistan
    Posts
    12
    Points
    663
    Level
    dc motor interfacing using 8051 and transistor
    Hello rksiwal!
    Check if the gnd of the whole circuit is same or not
    Last year i had to interface parallel port to 8051 and you know what i had done i just didnt connect the gnd of my 8051 to gnd of my db25 connector and when i connected the 2 the circuit went smoothly
    Good Luck
  3. #3
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    power transistor for driving motors by 8051
    thankx a lot sk_008 for the quick reply. but i have connected all the gnd.
  4. #4
    Advanced Member level 3
    Points: 8,212, Level: 21
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    how to drive motor with transistor and at89s52
    Here are some problems in your circuit.
    There is no crystal.
    There is no reset circuit for microcontroller
    EA pin is floating. Connect it to +5V
    No power connected to microcontroller
    Pin 2 of DB9 should go to Tx and pin 3 should go to Rx through MAX232.
    Base resistors of transistors are too small. Use atleast 1k.
    There are no free-wheeling diodes across relay coils.
    Second pair of relay has no power !!
    Its good to use 4.7k pull-up on P2.
    1 members found this post helpful.
  5. #5
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    microcontroller at89s52
    thankyou CMOS .sorry bothering you but could u plz explain the following.
    1. concept of freewheeling diodes. i know they are used to cater for back EMF but i m not clear about their orientation and rating(specifications).
    2. how to place free wheeling diodes when used across dc motor driven through H bridge. I am using 24V 2.5A supply to be relayed to motors.
    3. how do u decide that base resistance should be 1k and not anything else.
    4. kindly clarify "4.7k pull up on P2".
    thankyou very much
  6. #6
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    at89s52microcontroller based projects
    Read this article on freewheeling diode
    http://en.wikipedia.org/wiki/Flyback_diode
    And read this article on using transistor as a switch
    http://www.rason.org/Projects/transwit/transwit.htm
    Since sourcing current of ports of 89S52 is very low, you need to use external pull-ups to increase the sourcing current. Connect individual 4.7k resistor from +5V to each used port pin.
    •   Alt1st September 2009, 14:00
      advertising
  7. #7
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    8051 emc reset problem
    thank you CMOS your advice helped and so i m mentioning it by giving u pts.
    •   Alt1st September 2009, 14:34
      advertising
  8. #8
    Member level 5
    Points: 1,732, Level: 9
    Join Date
    Feb 2007
    INDIA-TAMILNADU
    Posts
    83
    Points
    1,732
    Level
    9
    two motors on a single microcontroller
    Hai,
    You can use L293 or L298 device called H bridge.
    So you can control speed also for your motor.No need of relay.
  9. #9
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    pc interfacing of microcontroller at89s52
    Quote Originally Posted by rksiwal
    No problem. And thanks for the points :)
    I forgot to mention free-wheeling diode's ratings. You can use 1N4007 across the relay with cathode connected to +12V and Anode to collector of transistor.
    You should also consider using a snubber circuit across the motor since it is powered from the same power-supply as the microcontroller, any noise generated by the motor will affect microcontroller's operation.
    http://homepages.which.net/~paul.hil.../Snubbers.html
  10. #10
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    at89s52 micro-controller
    hello..
    another strange problem has come.
    there are two circuits - 1st made by me, 2nd- development board purchased from vendor.
    Case 1 : when I put micrcontroller in 2nd board, give it +5V and GND from my circuit(1st board) and connect its(2nd boards) output pins to my board(1st), everythng works fine.
    Case 2 : Now I take out that same micrcontroller from 2nd board and put it in my board(1st). Now 1st board is not connected to 2nd board in anyway. Now the cicruit does not work.
    I have made the reset circuit and put the crystal also. I have attached the power up schematic kindly suggest corrections.
    In case 2 , when circuit is powered, I have measured voltage across
    pin20 - pin40 -5V
    pin 20- pin 31 -5V
    pin 20 -pin9 -0V
    Voltage are measured from pin side of micrcontroller and not solder side, so probability of loose solder is also ruled out. This is a very strange behaviour ..i could not understand .plz help out.
    One thing not drawn in diagram is pin40 is +5V
    pin 20 is GND connected.
  11. #11
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    areas where microcontroller is used in motors
    Ok there your problem is. Your reset pin is floating when reset switch is not pressed !
    You need to have logic 0 at the pin all the time for proper operation. Use R-C reset circuit as shown in the attached schematic.
  12. #12
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    pin ea at89c52 de trong
    thanx a lot CMOS...
    u really g88.....
    i have become ur pankhaaaa..... :)
  13. #13
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    Re: AT89S52 MICROCONTROLLER USED TO DRIVE 2 MOTORS
    So is your circuit working now?
    What is pankhaaaa?? What language is that?
  14. #14
    Newbie level 5
    Join Date
    Aug 2009
    Posts
    9
    Points
    819
    Level
    Dear all
    kindly see attached schematics and give suggestions.. see files in sequence
    The project is working but i believe i would have made mistakes some protection circuit or something like that..
    and yes I have tried to put some LEDs in file 2 which i have still not put on circuit ..but plan to put it...kindly make corrections for LED's
    kindly give opinions regarding the schematic.. 3rd file is the file one.
    Thanks to all for their kind effort.
  15. #15
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    Here are some issues with 3rd design.
    There are no current-limit resistors for LEDs.
    You can't drive a relay with LEDs in series. Connect LED with series resistor across the relay coil pins. Same applies for reset pin. You can't connect LED that way.
    No snubber circuit across motors.
    MAX232 circuit is not right. There should be a capacitor between pin 2 and Vcc.
    I am not sure what your motor's current rating is but keep in mind that 7812 is capable of delivering only 1A that too after using a large heat-sink.
    It is a good practice to use 0.1uF de-coupling capacitors near power pins of each IC.
    No need of 10k resistors before ULN2803. Instead use 4.7k pull-ups on those 4 pins. I've had problems earlier driving ULN2803 with 89S52 without pull-up.
    •   Alt3rd September 2009, 22:50
      advertising
  16. #16
    Points: 382, Level: 4
    Join Date
    Dec 2010
    Posts
    Points
    382
    Level
    we are using at89s52 micro controller for fingerprint based lock using stepper motor. initially we want an assembly program for led blinking for which we are using Kiel software ,later we will insert a buzzer in the place of led.
