+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Points: 705, Level: 5
    Join Date
    Apr 2009
    Posts
    Points
    705
    Level
    3.3v darlington array
    Attached the snapshot of ULN280x datasheet. I think I need to use ULN2801 (without base series resistor) as my GPIOs are 3.3V Vdd logic and can source only 2 ma from each GPIO. The Voh and Vol for the GPIOs are 2.66 min and 0.66 max respectively. Will my MCU GPIOs able to drive the ULN2801 which inturn are connected to the relays.
    http://www.st.com/stonline/products/...re/ds/1536.pdf is the link to full datasheet of ULN280x.
    Is ULN2801 suitable for the 3.3V GPIOs?
    Also help me understand the calculation of base current / voltage required to switch on the Darlington array of ULN280x from the datasheet. For example how did they come up with Ii (ON) of 0.35ma typ and 0.5max for ULN2804A at Vi = 5V?
    Thanks
    •   Alt29th August 2009, 15:31
      advertising
  2. #2
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,517
    Points
    239,611
    Level
    100
    darlington array 3v3
    You shouldn't, if you don't want to damage the CPU I/Os. 2803 is still fine at 3.3V voltage node, as the datasheet clarifies.
