+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 5
    Points: 663, Level: 5
    Join Date
    Jul 2009
    Posts
    10
    Points
    663
    Level
    transmission gate sizing
    I am unable to decide how to size a transmission gate. I sized them in the ratio of their unCox. The delay is not a huge concern, because the sampling capacitance is very small. Is that it, or some other factor like channel charge injection has to be considered?
    Thanks for your help.
    •   Alt26th August 2009, 21:55
      advertising
  2. #2
    Super Moderator
    Points: 50,308, Level: 54
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,873
    Points
    50,308
    Level
    54
    nsmission gate
    Quote Originally Posted by analog2003
    In most cases, equal w/l ratios for both p- and nfets are used. But sizing according to their µCox-ratio is also fine, I think.
    Make the w/l as small as possible, just big enough for your max. delay requirement. If 2 or more transmission gates have to match, consider the necessary w*l product for your matching requirement.
    Channel charge injection very often is a problem. Consider at least the simplest compensation method with (1/2)*(w/l) anti-phase-switched drain-to-source-shorted compensation fets.
    2 members found this post helpful.
