+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 2
    Points: 600, Level: 5
    Join Date
    Aug 2009
    Posts
    Points
    600
    Level
    problem with code
    hi,
    i m facing problem with code, actually
    if have a matrix of any dimension , i have any whole row and whole column zero in a matrix and want to delete this row n column from this matrix but im unable to understand how to delete this row n column i.e. i should get the matrix with reduced dimension
    b is a matrix of "n" dimensions
    and supppose its 2nd row n 2nd column is zero i want to delete this whole row and column
    for i=1:n
    for j=1:n
    if find(b(i,j)~=0)
    table(i,j)=b(i,j);
    else
    continue
    end
    end
    end
    thanks
    •   Alt25th August 2009, 06:31
      advertising
  2. #2
    Points: 15,530, Level: 30
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    problem with code
    I can not understand you. Your program say that any value not equal to zero will be copied to table(i,j), what do you need exactly?
    •   Alt25th August 2009, 14:22
      advertising
  3. #3
    Newbie level 2
    Join Date
    Aug 2009
    Posts
    Points
    600
    Level
    Re: problem with code - deleting rows and columns from matri
    i,ve solved the problem sorry i couldnt explain it well i had to delete entire row n column frm a matrix i just equate that particular row n colum to [] and got the required result
