+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 6
    Points: 1,345, Level: 8
    Join Date
    Nov 2005
    Posts
    13
    Points
    1,345
    Level
    8
    corner frequency
    Hi folks,
    There is active RC filter with frequency tuning circuit. The tuning circuit results indicate that the RC time constant tends to be large. But the bandwidth of the filter tends to be wide. Is there any factor introducing the discrepancy? Thanks!
    •   Alt25th August 2009, 05:54
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    tuning
    I like to answer you - however, I don´t understand your question, sorry.
    •   Alt25th August 2009, 08:39
      advertising
  3. #3
    Newbie level 6
    Join Date
    Nov 2005
    Posts
    13
    Points
    1,345
    Level
    8
    rc frequency chart for germany
    Thanks for your intention! The situation is that RC variation can vary the corner frequency of active RC filter. For keeping track of the RC variation, tuning circuit is used.
    •   Alt25th August 2009, 08:48
      advertising
  4. #4
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    rc filter
    Quote Originally Posted by linuxwinner
    Yes, but what is your problem now ?
  5. #5
    Newbie level 6
    Join Date
    Nov 2005
    Posts
    13
    Points
    1,345
    Level
    8
    rc circuit corner frequency
    The problem is that:
    Tuning circuit detects that master RC time constant is large. Large RC time constant means that the slave RC in active RC filter should be also large such that bandwidth of the filter should be narrow. But actually, the bandwidth of the filter is wider than expected. How come there is discrepancy?
  6. #6
    Member level 2
    Points: 2,018, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    Hungary
    Posts
    42
    Points
    2,018
    Level
    10
    calculate rc corner frequency
    It would help a lot if you would show us a drawing from the circuit.
    •   Alt25th August 2009, 11:33
      advertising
  7. #7
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    active rc filter
    Quote Originally Posted by tzg6sa
    Yes, I agree. How could we know without any drawing?
  8. #8
    Advanced Member level 3
    Points: 8,587, Level: 22
    rfsystem's Avatar
    Join Date
    Feb 2002
    Germany
    Posts
    914
    Points
    8,587
    Level
    22
    rc filter circuit
    As I understand is that the reference circuit indicating that 1/RC is lower than your reference clock frequency. But the change on the filter circuit is that the bandwidth is set to higher frequencies.
    This is correct!
    If you verify both, the reference tuner and the filter and apply the same process/temperature depend RC, the filter sould be with the tolerance or resolution of the setting method.
