[SOLVED] a VHDL error "Operator"+"is not defined for s
A
ahmadagha23
a VHDL error
Hi;
I want to use some symbols as delay time for signal assignements. So I use the following lines for this purpose:
constant Tbuff : integer:=5;
constant Tcable : integer:=7;
begin
a <= b after Tbuff +Tcable;
but I receive these error messages when I compile them. Would you please help me to resolve this errors?
ERROR:"Operator "+" is not defined for such operands."
ERROR:"Time expression expected."
Regards
a VHDL error
You have to provide "a <= b after (Tbuff+Tcable) ns";
Change "ns" to what ever time scale unit
Re: a VHDL error
I did it but the following error message arised:
ERROR: "Keyword "when" expected"
a VHDL error
put up your complete code so that it will be clear at which line it is pointing?
