+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Advanced Member level 1
    Points: 5,813, Level: 18
    Maverickmax's Avatar
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    how to test a thyristor
    Hi
    I am currently carrying out a damage on battery charger and stumbled on problem as it would not operate. I suspected it was a thyristor and I have no idea how to test it. Two thyristors are in the thyristor bridge circuit configuration with two subbers cicuit fitted across the thyristor respectively. I took the subber out of way and I was not entirely sure how to test it with DMM? Is there any different mehtod of test the SCR module? I look forward to hear from you intelligent guys
    Regards
    MM
    •   Alt13th August 2009, 13:09
      advertising
  2. #2
    Full Member level 5
    Points: 3,601, Level: 14
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Minnesota USA
    Posts
    297
    Points
    3,601
    Level
    14
    test thyristor
    A method I've used is:
    Ohms range on the DMM
    + lead to the SCR's anode
    - lead to the SCR's cathode
    Should read infinite if good
    Short the gate to the anode
    Should read low resistance if good
    With smaller SCRs the low reading should remain after the short is removed.
    With large SCRs the reading may go back to infinite after the short is removed, because the DMM current is below the SCR's minimum hold current.
    Ken
  3. #3
    Advanced Member level 5
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    scr thyristor
    Is there any way to check Triacs which are basically two scr's connected Cathode to Cathode?
    •   Alt14th August 2009, 06:52
      advertising
  4. #4
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Minnesota USA
    Posts
    297
    Points
    3,601
    Level
    14
    thyristor testing
    Same way as the SCR...almost:
    + lead to the triac's anode-2
    - lead to the triac's anode-1
    Short the gate to the anode-2
    - lead to the triac's anode-2
    + lead to the triac's anode-1
    Ken
  5. #5
    Member level 5
    Points: 1,976, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    80
    Points
    1,976
    Level
    10
    thyristor test
    please, how can i learn effectively how to use TRIAC and THYRISTOR. I have good and practical understanding of bipolar transistors and MOSFET. Any good link or tutorial will be highly appreciated as i intend to use triac with microcontroller to switch 220vac to 240vac to a pump motor without using relays. Can it be achieved?. Finally, what is the difference between SCR and Thyristor and Triac. thanks
    •   Alt14th August 2009, 14:43
      advertising
  6. #6
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Minnesota USA
    Posts
    297
    Points
    3,601
    Level
    14
    test scr
    SCRs and triacs are both thyristors.
    You might want to start here:
    http://www.allaboutcircuits.com/vol_3/chpt_7/index.html
    For interfacing microcontrollers with triacs:
    http://www.st.com/stonline/products/...re/an/1863.pdf
    Ken
  7. #7
    Member level 5
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    80
    Points
    1,976
    Level
    10
    how to test thyristor
    i will check the links and post any doubt here. Thanks for the reply.
