Orcad Error, Please if possible check this Lib in your Orcad
hcs2536
Newbie level 3
UK
orcad error codes
Hello my friends,
I use Orcad 16-2, I want to use AD8114 which is attached this part (.Olb) but I don't know why I have 2 errors:
ERROR [NET0085] Part AD8114.U1A has no 'MODE' property
ERROR [NET0077] Pin in template not found on AD8114.U1A
I don't know what's in?? I define IN00~15 as shown in PspiceTemplate, and I selected just for
Implementation Type: Pspice Model
and also define,
PspiceTemplate
IC_U1A^@REFDES %UPDATE* %RESET* %SER*/PAR %DATAOUT %DATAIN %CLK % CE* %A0 %A1 %A2 %A3 %D0 %D1 %D2 %D3 %D4 %IN00 %IN01 %IN02 %IN03 %IN04 %IN05 %IN06 %IN07 %IN08 %IN09 %IN10 %IN11 %IN12 %IN13 %IN14 %IN15 %OUT00 %OUT01 %OUT02 %OUT03 %OUT04 %OUT05 %OUT06 %OUT07 %OUT08 %OUT09 %OUT10 %OUT11 OUT12 %OUT13 %OUT14 %OUT15 @MODE
but I don't know why <pin in> and also I've checked pins and I've also looked at Capture/Open/Library../AD8114.olb and Right_Click /Edit Part with pins but all of them are matched.
Main aim: Could you please check this lib in your Orcad and tell me this lib is correct or not, I just want to check it with your Orcad may find my mistake and if you find my mistake please tell me what's my mistake to correct me, thanks a lot,
Oh sorry, I do apologise for long post and english.
Thank you so much for your attention.
error [net0077]
some libraries in orcad is only for schematic not for simulating,
check it if it is such a this format.
