+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 5
    Points: 2,722, Level: 12
    Join Date
    Jan 2000
    Posts
    94
    Points
    2,722
    Level
    12
    float32
    Hi everybody,
    i have min 0 and max 20
    The value 0,1 is what in hex?
    How is the way of calculation?
    Dos excel support this?
    Thanks
    BR
    Vauxdvihl
    •   Alt3rd July 2009, 16:22
      advertising
  2. #2
    Banned
    Points: 7,016, Level: 19
    Join Date
    Apr 2009
    New Jersey, USA
    Posts
    671
    Points
    7,016
    Level
    19
    float32 hex
    Hexadecimal notation doesn't support fractional numbers - only whole numbers.
    •   Alt3rd July 2009, 17:35
      advertising
  3. #3
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    dec2hex excel
    Vauxdvihl,
    Multiply 0,1 By 2^32 in decimal. The result is 429496729.6
    Round the result to an integer. The result is 429496730.
    Convert the integer result to Hex. The result is 1999999A.
    The result is the base 32 representation of the fraction with the MSB having a weighting of 0,5.
    Excel has a function "DEC2HEX" That converts decimal to hex. So you would do the multiplication and rounding in Excel, and then use "=DEC2HEX(429496730,8) to get the final result.
    You must install the Excel Analysis Tool Pack in order to get the function "DEC2HEX" in Excel:
    On the Tools menu, click Add-Ins.
    In the Add-Ins available list, select the Analysis ToolPak box, and then click OK.
    If necessary, follow the instructions in the setup program.
    Regards,
    Kral
    Added after 2 minutes:
    I'm not sure how the smiley face got into the reply. It should read =DEC2HEX(429496730,8)
    It got in there again! the characters after the comma should be 8). Can anybody help me on this?
    One more try! The characters after the comma should be the numeral 8 followed by a right parentesis. Help!!
    •   Alt3rd July 2009, 19:36
      advertising
  4. #4
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    excel dec2hex install
    Either avoid smiley character combinations in your post, e.g. inserting a space between "8" and ")", or select "Disable Smilies in this post".
  5. #5
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    what is float32
    Fvm,
    Thanks for the Smiley Face tip!
    Regards,
    Kral
  6. #6
    Member level 5
    Join Date
    Jan 2000
    Posts
    94
    Points
    2,722
    Level
    12
    float32 to hex
    The ranges 0 -20 must not be considered?
    Thanks
    Added after 2 hours 45 minutes:
    It is very strange, because your result does not match with
    http://www.h-schmidt.net/FloatApplet/IEEE754.html
    Enter value 0,1 and you receive another value then you provided one.
    Also a kollege is sending me this information:
    mit 32bit ist bei
    Min: 0 und
    Max: 20.0
    eine Auflösung von: 0,000000004656612873077392578125 möglich (0 bis 4294967295).
    Das bedeutet 20 entspricht 4294967295 = 11111111111111111111111111111111 = FFFFFFFFhex.
    Das bedeutet 0 entspricht 0 = 00000000000000000000000000000000 = 00000000hex.
    Das bedeutet 0,1 entspricht 21474836 = 1010001111010111000010100 = 147AE14hex
    I am lost, what is right?
    Thanks
  7. #7
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    float32 ieee
    Vauxdvihl,
    The algorithm I gave is strictly for converting a decimal fraction to a hex representation. If you want to convert to IEEE-754 you must do the additional work of incorporating the "invisible" leading 1, the sign and the exponent.
    Regards,
    Kral
    Added after 26 minutes:
    For an example of the conversion process, see the article at:
    http://people.rit.edu/jdweme/labview...Conversion.pdf
    •   Alt6th July 2009, 17:23
      advertising
  8. #8
    Member level 5
    Join Date
    Jan 2000
    Posts
    94
    Points
    2,722
    Level
    12
    how to convert decimal to ieee 754 hexadecimal
    I need it for a µC Star12 from Freescale XET device
    Thanks
    BR
    Sascha
    I was not aware that there are different standards of converting a number
