Confusion in pins of FPGA kit and Chip pins
saurabhmimani
Junior Member level 1
pins of fpga
hi
I was using a spartan 2 kit in whose manual pin numbers of different IO"S are given as simple numbers as 77, 80 and so on, I don't know how to get pin number of spartan 2 FPGA respectively. I am using Universal DSP trainer from MTE Pune with Spartan 2 PQ208, manual can be downloaded from
https://www.mte-india.com/Product/InstallProc/UNI-DSP_MANUAL.pdf
please write anything you know that can help me.
Thankyou.
pins for fpga
If you're using ISE, each line starting with "Net" is placed in a UCF text file. Include only the lines that are needed.
For example, you probably want to use the onboard 4 MHz oscillator for your clock. So, in your UCF file, you type the following line:
Net "CLK_4M" loc = "77";
Your input port for the clock signal will need to be named CLK_4M.
If you want to be different, you can change the name of the signal from CLK_4M to some other name.
operation manual for spartan-2 trainer example
Yeah, I am completely agree with your point, I tried the same thing you have said but I am getting the following error-
ERROR:MapLib:30 - LOC constraint 77 on CLK_4M is invalid: No such site on the
I am coding the following simple blink_led code just to test inertially working of the kit for spartan 2 XC2s200 PQ208-
module blink_led(out,CLK_4M);
output out;
input CLK_4M;
reg out;
reg i=1'b0;
always @ (posedge CLK_4M)
begin
if(i)
out=1'b0;
else
out=1'b1;
i=i+1;
end
endmodule
Hi
Why do you need where the points are?You can just copy the required UCF pins from the manual and add it in your UCF file and run the program.
Added after 1 minutes:
Connect OUT to output pin you have mentioned to output LED in UCF.
Input to input of fpga(where input pins are mentioned)
@ Tan
yeah, but I am getting the error i have mentioned but I am getting the error i have mentioned because manual is saying you will get clock on pin77 but there is no 77 pin number in spartan 2 fPGA.
I don't know am I able to convince what my problem is because when I copied the required pins from the manual in the UCF file I am getting the error.
Thanks for reply.
With the latest versions of ISE, you will need to amend the pin numbers by adding "p" (as in the data sheet), as follows:
Net "CLK_4M" loc = "p77";
Net "out" loc = "p204";
