+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 6
    Points: 4,473, Level: 15
    Join Date
    Nov 2003
    Brazil
    Posts
    372
    Points
    4,473
    Level
    15
    tl494 smps
    Need a 12V in +48V & -48V 3A out simetrical SMPS to power a car amplifier with TDA1514 (Philips) with TL494 and BUZ71 and filters due to noise generation can malfunction electronic fuel ingection and board computer of my car, a FIAT UNO MILLE.
    If possible using parts saved from AT/ATX computer power supply.
    Regards,
    Fernando
    •   Alt25th February 2004, 13:38
      advertising
  2. #2
    Full Member level 2
    Points: 3,169, Level: 13
    Join Date
    Apr 2001
    Posts
    142
    Points
    3,169
    Level
    13
    smps car audio
    It looks as if u want to make professional amplifier. Further TDA1514 is a discontinued IC of Philips. For car SMPS u can visit Rod elliot site. There is ready circuit which any body make with some knowledge.
    MP
    •   Alt25th February 2004, 18:29
      advertising
  3. #3
    Junior Member level 1
    Points: 1,684, Level: 9
    Join Date
    Jan 2004
    Helsinki, Finland
    Posts
    16
    Points
    1,684
    Level
    9
    tl494 car smps
    Yep, a PC power supply gives you the most critical (or hard to find) components: the magnetics for the transformer. Also the schottky diodes are often usable.
    For the rest you just need some low ESR caps, an SG3525 or something like that, and two low RDSon high current (but low voltage) mosfets like IRFZ44N or so.
    Bert
    •   Alt25th February 2004, 18:56
      advertising
  4. #4
    Full Member level 6
    Join Date
    Nov 2003
    Brazil
    Posts
    372
    Points
    4,473
    Level
    15
    smps for car audio
    Palesha, thank you again the tip. That's an amazing site with lot of usefull information abaout audio.
    Bert you got the idea. and you were right have some PC AT/ATX smps in my junk box so save some parts (more often hard to find) is a nice idea.
    Thanks for both.
    Fernando.
  5. #5
    Full Member level 2
    Points: 3,347, Level: 13
    Join Date
    May 2002
    Posts
    120
    Points
    3,347
    Level
    13
    smps car
    Also check: http://www.diyaudio.com/
    Search the forums for smps, dc-dc, power suplies or simular. Thera are many topics about how to make them for car audio. You would also find a lot of people that have built different versions of the one from Elliott Sound Products recomended i erlier post...
    re Me
  6. #6
    Points: 2,049, Level: 10
    Join Date
    Sep 2001
    Posts
    17
    Points
    2,049
    Level
    10
    car amplifier smps
    Email me glenn-garrett/@/iinet.net.au/noslashes
    I have a design using cores from pc p/s and a few other parts
    •   Alt12th March 2004, 03:45
      advertising
  7. #7
    Points: 1,645, Level: 9
    Join Date
    Jan 2004
    Posts
    Points
    1,645
    Level
    9
    tl494 car audio
    Pls go to the link
    http://sound.westhost.com/
