How to change the drill size of a PAD in Orcad Layout?
ronydc
Full Member level 3
dear friends,
i hv 2 problems stated below. plz show me the way.
1>I could never been able to change the drill size in "orcad layout" for any componant. WHY IN ORCAD WE CANT CHANGE THE DRILL SIZE FOR A PAD .?
2> when i opn the librery manager in layout, In the padstack librery i dont find any pads. WHY .? is this normal or any problem with my software .?
i m been using this software version ORCAD-9 since years.. without any problem
plz plz plz show me the way.. my main problem is "how to change the drill lsize of a PAD in layout.
--confused Rony.
orcad layout problem
ronydc said:
dear friends,
1. In "Options" menu, select "User Preferances".
2. Marck "Allow Editing of Footprints".
3. In working area, pick the "Pin Tool" button.
4. Left click + Ctrl ,on the pin that your change.
5. Select "View Spreadsheet" button and select "Padstacks.
--confused Rony.
    ronydc
orcad layout padstack spreadsheet
dear friend..
it was nice attempt to show me the way . but u hv mistaken one place. understanding my question.
my main problem is --> how to change the DRILL size of a pad.
u shown me -- how i can change the pad dimensions. and that i already know ( thanks for tht)
my question still remains the same and unanswered --- HOW TO CHANGE THE DRILL SIZE OF A PAD IN ORCAD LAYOUT PLUS ..?
If any one else can help me...
--still confused rony.
change drill hole dimension in orcad
On the same padstack spreadsheet you will find DRILL and DRLDWG row. double click and change drill values.
Thanks...
    ronydc
change drill size orcad
ronydc said:
dear friend..
In "Layoou.gif" modify the 0.89. OK?
orcad create pad
oh thanks friend this sounds very intresting...and usefull..
ohh i will surely try and will reply here.. just wait to have a BIG thanks from me..!!
-- happy Rony.
drill / drldwg
You cannot change dimensions of pad directly..first create the footprint then using padstack window change the properties of pads.
If u want different pads double click the pad then chose different padstack....
then change the properties of all pads in padstack window(shift+t)
i have attached some libraries check for your reference...
orcad layout reference
thanks friends all of u helped me..
-- happy rony
Added after 1 minutes:
dmd.. thnks for trying to help me but u forgot the libraries to attach..
