How a self-biasing circuit (latch) is done ?
kickbeer
Full Member level 3
As in most of the other designs of the latches, there is always a biasing transistor
connected to the source of the NMOS in the regenerative loop. In that architecture, the biasing transistor is eliminated and self biasing techniques are used to attain required voltage levels and therefore rail to rail output is closely achieved. How a self-biasing circuit is actually accomplished?
Thx in advanced
self bias circuit
it wil be much easier, if u can post the schematic of the ckt which u refer 2
thanks,
self biasing
thanks,
see the file in attachment. It's a latch
self biased transistor
In reference to u r ckt,
M12 and m13 act as pre charge devices which pull either of out- or out+ to vdd (its explained how this happens in CS amp with diode/active load in razavi)
If you use a resistor to do this job, there will b a drop across it so u r output can't reach vdd any time. which is not the case when u use a pmos device.
the same principle applies to bottom nmos device(but it will be close to zero)
so in total u will get rail to rail swing.
Hope this helps.
Let me know for any clarification.
thanks,
    kickbeer
self biasing circuit
thx very much for that answers. it's really helpful. But i'm still not clear of the function of transistor M5 and M6. Do they amplify the signal in_com+ and in_com-? These two signals are output of the differential amplifier (not seen and the attachment).
low voltage self-biasing reference circuits
There are three state for the circuit:
1,0, and bi-stable state
when the clk is high, the self biasing circuit(regenerative circuit) strives out of the former 1 or 0 state, Vout+ and Vout- settle down to the same voltage( at least very closely voltage level).
when the clk is low, the branch of vin- or vin+ ( which one is low enough)will sink a current from the self biasing circuit, the vout+ or vout- node is pulled down, the self biasing circuit will funciton as a positive feedback circuit, make the low one more lower, make the high one more higher.
M5 and M6 are used to read the input signals.
    kickbeer
why use self bias in a circuit
I'm not so clear with the sentence 'to read the input signals'. Do they amplify input signals?
