+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 1,446, Level: 8
    Join Date
    Jul 2005
    USA
    Posts
    19
    Points
    1,446
    Level
    8
    orcad capture problems
    Hi dear all Friends
    I have designed a schematic which has some parts seperated from each other I mean for example I devided FPGA device to 3 seperate part: Power, Control, Data... So I want to define them as a single part and define a footprint for that can i connect them togather?
    I used part manager to creat a new group and added all pices of FPGA part to a group and I defined footprint for all pices the same
    however when I created the netlist and mounted it to layout,three FPGA pices appeared as seperate parts!!!!
    how can I define that thise three pices belong to one part?
    Thanks of your responses
    •   Alt27th June 2009, 00:51
      advertising
  2. #2
    Full Member level 5
    Points: 3,795, Level: 14
    Join Date
    Dec 2002
    Posts
    288
    Points
    3,795
    Level
    14
    create multi-part package orcad
    This is explained in detail in OrCAD help. You should assign package attribute to each part.
    M
    •   Alt27th June 2009, 04:03
      advertising
  3. #3
    Points: 14,157, Level: 28
    Join Date
    Jun 2005
    Stanford, SF Bay Peninsula, California, Earth, Solar System, Milky Way
    Posts
    1,418
    Points
    14,157
    Level
    28
    define homogeneous and heterogenenous parts orcad
    When you've created the library package for your FPGA, you made several parts inside that package. Probably, they were called U?A, U?B, U?C, etc. When you place the part, you get a "Place Part" dialog. At the bottom of this dialog is a frame called "Packaging". You should select each part (A, B, C, etc; one at a time) and place them. If you get designators U1A, U2B, U3C, instead of U1A, U1B, U1C, just edit the numeric parts of the designators in the schematic.
    Hope it helps. Hope, I understood your question correctly.
    BTW, here a good resource on OrCAD: http://tech.groups.yahoo.com/group/OrCADexchange
    - Nick
    1 members found this post helpful.
    •   Alt27th June 2009, 21:20
      advertising
  4. #4
    Join Date
    Jul 2005
    USA
    Posts
    19
    Points
    1,446
    Level
    8
    orcad create multiple parts package
    Hi and thanks of your response
    I could not find any thing related to how make seperate parts to be a pacjage in help documents, however it has some explanations for that
    can you tell me where I can find a tutorial for that? since I studied ttutorial flow and user guide of Orcad capture!!
    I am using version 16.2
    thanks
    Added after 53 minutes:
    thanks guys I could solve it
    :D
  5. #5
    Newbie level 5
    Points: 767, Level: 6
    Join Date
    Feb 2009
    Posts
    9
    Points
    767
    Level
    orcad layout page frame -session
    If u are about to create a library.First u need to decide it can be made in single part or multiple part..based on this u have to create the library and declare the properties
    step1 : create a new symbol
    in that dialog box whcih appears ..there wil be option called PACKAGE TYPE
    there will be 2 options
    1 .Homogeneous
    2. Heterogeneous
    Homogeneous refers to single part symbol..u need to enalbe this in order to create a single sy,bol
    Heterogeneous is used to create multiple parts for a single symbol
    so u need to enable this option to create multiple part in a single symbole
    pls try this ..if still any error occurs let m eknow
