+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 655, Level: 5
    Join Date
    Jun 2009
    Pakistan
    Posts
    7
    Points
    655
    Level
    inverter design
    I'm designing a mosfet based single phase inverter using h-bridge
    I'm using PIC controller to control the mosfets
    The problem is that even for low duty cycle pulses, the mosfet keeps conducting for a much longer period than it should and at high frequencies (close to 40Hz), one of the high side transistors starts heating up... so.. i think that the problem is with turn-off (transistor is taking too long to turn-off)... so, i want to employ an RC snubber circuit in parallel or something else... can anyone help me by telling me what values i should use or whether or not there is a better alternative
    •   Alt25th June 2009, 13:41
      advertising
  2. #2
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,577
    Level
    100
    mosfet based inverter
    A snubber shouldn't be supposed to reduce the said issues. It rather sounds like bad gate drive.
    1 members found this post helpful.
  3. #3
    Junior Member level 3
    Points: 2,106, Level: 10
    Join Date
    Sep 2005
    Posts
    26
    Points
    2,106
    Level
    10
    mosfet inverters
    What kind of gate drive circuit do you use ? for PWM inverters you must use a dedicated IC like IR2110, 2113 which can charge/discharge MOS-FET gate very fast. if you used a simple circuit like in modified sine inverter, with just one transistor and resistor for chare/discharge, this is the result.
    there are other options too, like fast optocoupler followed by a gate drive, or gate transformer, but the ideea is to be able to source/sink current fast enough, in terms of tents of nS. also the gate resistor must have the value b etween 10-47 ohms, and frequently is connected in parallel with a diode which have the role to dischae the gate faster than it charge.
    •   Alt26th June 2009, 07:41
      advertising
  4. #4
    Join Date
    Jun 2009
    Pakistan
    Posts
    7
    Points
    655
    Level
    inverter mosfet
    Thanx for the reply
    The diode helped
    It's better now
    But still, it tends to get a little hot
    I was using an optocoupler, connected to BS170 (n channel mosfet) connected to buk438 (power mosfet)
    Though the heating has reduced significantly, the voltages haven't dropped to the value they would've had the actual on-time of the mosfet been equal to that of the controller's port pin
    I'll try the IR2110
    Thanx
  5. #5
    Member level 2
    Points: 2,257, Level: 11
    julioreye's Avatar
    Join Date
    Jun 2006
    Posts
    47
    Points
    2,257
    Level
    11
    inverters design
    i was using an optocoupler hcpl 3120 and hcpl 4504, they have high speed and high CMR, you should to use faster components.good luck.
  6. #6
    Join Date
    Jun 2009
    Pakistan
    Posts
    7
    Points
    655
    Level
    hcpl-3120 inverter
    will do
    thanx
    •   Alt29th June 2009, 11:12
      advertising
  7. #7
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    inverter with mosfet
    Hi adilmahsan,
    Use optocoupler hcpl 3120 to interface Microcontroller with IR2110/2113 to drive the Mosfets in High Side and Low side Mosfets can be driven directly without the use of IR2110. Since for 2 High side you require to use 2 IR2110 and those are High and Low side driver,you can use those 2 to drive both High and Low side Mosfets. One more suggestion, Please provide 1k resistor each for each Mosfets connected to source/ground from gate to offset the Miller Capacitance of the Mosfets. Thanks.
