+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 1
    Points: 2,039, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    microcontroller relay circuit
    Hello friends,
    I have problem interfacing 8051 controller with relay. I am using 12V relay to ON/OFF. The output port of the controller is set at logic zero, it gives 5V when it isnot active.
    But when inputs are applied it works according to the requirement but it gives 2V, when it is active.
    So if the relay is active it doesnot gets deactived at this point.
    i have attached the relay circuit.
    Plz help me, I need help soon.
    1K resistor is there between output port and base of the transistor.
    •   Alt20th June 2009, 16:58
      advertising
  2. #2
    Junior Member level 1
    Points: 904, Level: 6
    jeswanthmg's Avatar
    Join Date
    Jun 2009
    Bangalore
    Posts
    15
    Points
    904
    Level
    relay interfacing
    Dude just add 10K pull up resistor at the port pin.
    its simple
  3. #3
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    relay circuit for avr
    Like this:
    But the problem is I couldnot get less than 2V when microcontroller is active(that is when inputs are applied). I am using AT89S51.
    It's output is working on logic zero.
    I want to get less than 1V to properly operate the relay.
    •   Alt20th June 2009, 19:15
      advertising
  4. #4
    Advanced Member level 2
    Points: 6,569, Level: 19
    ctownsend's Avatar
    Join Date
    Nov 2004
    Canada
    Posts
    573
    Points
    6,569
    Level
    19
    requirement of pullup resistor in 8051 ports
    Quote Originally Posted by Adil Israr
    try a 4.7K resistor instead of the 1K resistor you are using. (between the pullup and the base on the transistor)
    I use the same with an 89C52 and it works reliably.
    •   Alt21st June 2009, 00:11
      advertising
  5. #5
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    8051 relay
    Everything is right whta you people said but my relay doesn't get deactivated, it activates all right but doesn't deactivate because of 2V.
    My AT89S51 gives maximum voltage of 5V when inputs are not applied, but it gives minimum of 2V when inputs are applied, I want to get less than 1V.
    How can I do this??
  6. #6
    ctownsend's Avatar
    Join Date
    Nov 2004
    Canada
    Posts
    573
    Points
    6,569
    Level
    19
    relay tansistor interfacing
    post your code.
    I see the circuit looks fine. Maybe you have a bad transistor, or one of the pins on your 89S51 is blown. Switch to another pin and change the code.
  7. #7
    Member level 4
    Points: 1,627, Level: 9
    herlambang's Avatar
    Join Date
    Apr 2009
    Indonesia
    Posts
    74
    Points
    1,627
    Level
    9
    74hc less than 1v
    Your circuit use active low.. you should use PNP transistor.. or change your circuit.
    in your circuit, the pin goes high on power on. it's activate the relay directly.
    Built in double watchdog! *problem solved*
    •   Alt23rd June 2009, 15:30
      advertising
  8. #8
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    how to connect relay with 8051?
    Actually my controller also works on active low, if I cahange the coding and make it active high. Will it work fine??
  9. #9
    jeswanthmg's Avatar
    Join Date
    Jun 2009
    Bangalore
    Posts
    15
    Points
    904
    Level
    microcontroller interfacing relay code
    Dude i thaught i solved your problem i forgot to check my mail
    ok you could change your software code and try
    actually i had same problem then when i added 10K pull up it worked fine
    1K current limitter is fine may be you should check your transistor also see that emitter of transistor is grounded.
  10. #10
    Full Member level 2
    Points: 1,937, Level: 10
    Join Date
    Jan 2009
    Pakistan
    Posts
    126
    Points
    1,937
    Level
    10
    code of relay interface with microcontroller
    Hi
    Its a very very bad practice to connect a relay with a microcontroller like this. the relay revers voltage will directly afect the microcintroller. here ic is comparitively high thus need more ib too. Use ULN type driver. or atleast use a 2 stage transistor amplifier. Or you can also use Open Collector Inverter or buffer. Or use a 74HC series buffer/inverter/latch and then use a single transistor drive for rlay.
    1 members found this post helpful.
