+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 1
    Points: 627, Level: 5
    Join Date
    Jun 2009
    California
    Posts
    Points
    627
    Level
    how to make stripline
    How can I design a matching circuit using microstrip series stub on a PCB?
    I have been looking around and never understand what is a series stub. I understand design using smith chart, I just don't get the physical structure using stripline or microstrip.
    Thanks
    •   Alt14th June 2009, 07:26
      advertising
  2. #2
    Advanced Member level 5
    Points: 32,294, Level: 43
    Join Date
    Oct 2001
    Posts
    4,623
    Points
    32,294
    Level
    43
  3. #3
    Junior Member level 3
    Points: 941, Level: 6
    Join Date
    Jun 2009
    Posts
    29
    Points
    941
    Level
    stripline stubs
    Don't try to use a series stub matching network when working with microstrips. It is much easier to implement using shunt stubs instead. Physically it is just a piece of microstrip conductor at a 90° angle to the microstrip line.
    •   Alt15th June 2009, 14:56
      advertising
  4. #4
    Full Member level 1
    Points: 2,726, Level: 12
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Uruguay
    Posts
    114
    Points
    2,726
    Level
    12
    series stub microstrip
    As YoungEng said is better shunt stub .
    Working frequency ?
    Bandwith ?
    Sustrate type ?
  5. #5
    Points: 11,265, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,265
    Level
    25
    shunt stub implement
    Both ( series and shunt) are essential if BW requirement is more.
    •   Alt16th June 2009, 10:26
      advertising
  6. #6
    Points: 33,056, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,643
    Points
    33,056
    Level
    44
    microwave stripline stub
    Simple series stubs are not possible in microstrip or stripline, as you can make a series structure in the top trace, but not in the ground plane underneath.
    Never the less, there are a number of series-like structures that can be used in stripline/microstrip. With some creativity, these can be included in matching structures. Look at Microwave Filters Impedance-Matching Networks, and Coupling Structures by Matthaei, Young, and Jones. On pages 219-228 there are a lot of depictions of such structures, although the models shown there are only accurate for TEM such as stripline, and not microstrip (which have εeven ≠εodd).
    Rich
  7. #7
    Member level 4
    Points: 1,112, Level: 7
    Join Date
    May 2009
    Dartmouth, NS
    Posts
    71
    Points
    1,112
    Level
    7
    Blog Entries
    stub series stripline
    You can do a lot with a series stub. With a 90degree phase shift at a given impedance you can transform to nearly any impedance.
    Here is a spreadsheet that will show you how to make them:
    http://www.microwaves101.com/downloads/Xfmr101Rev3.xls
    You can use it to make as many sections as you want. It only covers real impedances but you could tune it in your simulator for a complex match.[/url]
    The formula for a single 90 degree line is simple and as follows:
    ZT=(ZL*ZS)^0.5
