+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 3
    Points: 989, Level: 7
    Join Date
    Apr 2009
    Mumbai, India
    Posts
    54
    Points
    989
    Level
    7
    vhdl case statement
    when using the case statement for , it displays when others condition is not synthesized.
    is there any alternative for this .
    <code>
    f (STROB1= "01")then
    ADC_DATAMOS_TEMP <= ADC_DATAMOS;
    else
    ADC_DATAMOS_TEMP<= "ZZZZZZZZ";
    end if ;
    process (CLK_MOS,RST_MOS,ADC_DATAMOS,STROB1,RW_MOS)
    begin
    if (RST_MOS='0')then
    ADC_DATAMOS_TEMP <="00000000";
    elsif (RST_DAQ='1') then
    case ADDR_MOS is
    when "00001" => MOS_REG(0) <= ADC_DATAMOS;
    when "00001" => MOS_REG(1) <= ADC_DATAMOS;
    when "00001" => MOS_REG(2) <= ADC_DATAMOS;
    when "00001" => MOS_REG(3) <= ADC_DATAMOS;
    when "00001" => MOS_REG(4) <= ADC_DATAMOS;
    when "00001" => MOS_REG(5) <= ADC_DATAMOS;
    when "00001" => MOS_REG(6) <= ADC_DATAMOS;
    when "00001" => MOS_REG(7) <= ADC_DATAMOS;
    when others =>MOS_REG(8) <= ADC_DATAMOS; -- dummy register ..
    -- DUNNO WHAT TO DO IN - --THIS others PLEASE HELP
    end case ;
    end if;
    end process;
    </code>
    in the above case , i have a set of registers to which a data coming on the line is to be written basing on the address that we recieve .
    What shuld be written when others case ./???
    please help /
    •   Alt9th June 2009, 11:37
      advertising
  2. #2
    Member level 3
    Join Date
    Apr 2009
    Mumbai, India
    Posts
    54
    Points
    989
    Level
    7
    vhdl when statement
    Thanks a ton for the quick reply ,
    i was able to remove the synthesis error introducing a null statement in the others case.
    but ,
    the problem is with the warnings :
    Latch generated from process for signal DAQ_REG_6(7 downto 0), probably caused by a missing assignment in an if or case stmt.
    My question to you , is this others stament synthesizable ..?
    If it is null how is it synthesized.
    as i m to target the same to fpga also .
    •   Alt9th June 2009, 12:37
      advertising
  3. #3
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    case statement vhdl
    O.K. I didn't realize, that the case statement isn't placed within a clock sensitive condition.
    In the case statement, you assign one bit of MOS_REG and leave the others unchanged. This creates a latch anyway, the problem isn't related to the existence of an others statement. It's legal code, but most likely, it doesn't work as expected. For reliable operation, a clock sensitive condition should control the assignment, then a register rather than a latch can be synthesized.
    •   Alt9th June 2009, 13:10
      advertising
  4. #4
    Member level 3
    Join Date
    Apr 2009
    Mumbai, India
    Posts
    54
    Points
    989
    Level
    7
    vhdl case when
    But for some data Read write operations , can we have the operation clock dependent ?
    (as is the case in my above code, i am just performing read write operations on data.)
  5. #5
    Advanced Member level 5
    Points: 20,002, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,855
    Points
    20,002
    Level
    34
    case vhdl
    You could also use:
    When others =>
    MOS_REG<=MOS_REG;
    This will help the synthesizer, but you're still going to get latches. And their outputs are probably going to bounce around.
    I totally agree with FvM: Use a clock.
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    when statement in vhdl
    Remember that VHDL is a hardware description language, not a procedural programming language.
    Check which hardware is generated from your code and if it can give stable data output. In the present
    case, it can't.
    •   Alt10th June 2009, 19:08
      advertising
  7. #7
    Member level 3
    Join Date
    Apr 2009
    Mumbai, India
    Posts
    54
    Points
    989
    Level
    7
    case in vhdl
    Attention plese : FVM /others
    if i put these statements in a clock sensitive condition , can i ensure that it can generate hardware whch is stable.?
    I m currently using synplify , so i am not able to see what hardware it synthesizes.
    can u please tell me is there anyother tool through which i can also see the synthesized hardware .
    (installed PRecison RTL , awiating License .)
  8. #8
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,855
    Points
    20,002
    Level
    34
    when statement vhdl
    If you use a clocked process, and the output of the process is the input to another clocked process, it will be stable (or the tools will tell you if there's a timing error).
