+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Points: 674, Level: 5
    Join Date
    Jun 2009
    Posts
    Points
    674
    Level
    ecg con ad620a
    can i replace op97..what should be the amplifier if I don’t use it!!
    •   Alt2nd June 2009, 11:55
      advertising
  2. #2
    Advanced Member level 5
    Points: 48,700, Level: 53
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Toronto area of Canada
    Posts
    8,479
    Points
    48,700
    Level
    53
    ad624ad ecg circuit
    Your Word document is empty.
    Please post your schematic as a GIF or PNG file type.
    •   Alt2nd June 2009, 23:32
      advertising
  3. #3
    Join Date
    Jun 2009
    Posts
    Points
    674
    Level
    low noise opamp ecg
    I'm from Bangladesh..i am doing my final year thesis project..It is about vital signs monitor or patient monitor.so one part of our project is ECG .in our country we can't manage all the component that required for ECG circuit.i attested the circuit diagram.
    I have AD620A.but i cant manage OP97.
    I can't manage AD624AD.
    Availability of component in our country is very tough.
    so if you give me some idea about how do i solve out the problem briefly it ll be very helpful for me.
    thanking you,
    masba
    •   Alt4th June 2009, 08:36
      advertising
  4. #4
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,479
    Points
    48,700
    Level
    53
    replace for op97
    Did you look at the datasheet for the OP97 opamp? It has extremely low input offset voltage and offset current.
    You could use an ordinary low noise opamp and trim the offset yourself with a trimpot.
  5. #5
    Join Date
    Jun 2009
    Posts
    Points
    674
    Level
    ad624ad using ecg circuits
    would you please tel me the IC number of low noise opamp..if you mention a specific name it would be easier for me..
    •   Alt5th June 2009, 15:19
      advertising
  6. #6
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,479
    Points
    48,700
    Level
    53
    ad624ad ecg
    I do not know why you cannot buy any opamp that is made in the world like I can and I do not know which ones you can buy.
    There are many single low noise opamps made by Texas Instruments. The OPA134 is good and works from a supply as low as 5V.
  7. #7
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    Re: ECG op97 problem
    alternative is in atached
    masba, you can order and get samples (few pieces) of many IC's directly from various manufacturers like Analog, National,Texas etc. for free.
  8. #8
    Join Date
    Jun 2009
    Posts
    Points
    674
    Level
    ECG op97 problem
    Thanks Borber
