+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 4
    Points: 2,163, Level: 10
    Achievements:
    7 years registered
    kit_714's Avatar
    Join Date
    Jul 2006
    Posts
    70
    Points
    2,163
    Level
    10
    mosfet bridge rectifier
    Hi all,
    i would like to ask about the possibility of rectification of AC input using Mosfets instead of diodes....
    is that possible that by replacing all 4 diodes with 4 N-Mos for rectification with proper gate control circuit?
    The reason of using Mosfets rather than diodes is to reduce the loss on the rectification circuitry....
    Can anyone help me?
    Thanks,
    kit
  2. #2
    Advanced Member level 1
    Points: 7,503, Level: 20
    Awarapunshee's Avatar
    Join Date
    Jul 2007
    Some Where In Heaven
    Posts
    413
    Points
    7,503
    Level
    20
    mosfet rectifier
    This is what you want, everything expalined in it. I think it helps you.
    ENJOY!
    3 members found this post helpful.
    •   Alt27th May 2009, 05:53
      advertising
  3. #3
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    using mosfets
    Basically possible, but needing a rather complex driver circuit with an auxilary supply or bootstrap. The equivalent circuit is a H-bridge.
  4. #4
    Member level 3
    Points: 2,159, Level: 10
    Achievements:
    7 years registered
    Join Date
    Nov 2006
    Wrocław, Poland
    Posts
    62
    Points
    2,159
    Level
    10
    full wave rectifier
    In itself its not much of a problem ,i builded this before aswell discrete (transistors),with comperators as with IRF chipsets .
    Elektor published a schema a few years ago but i didnt like it cause it used 2 p-mosfets (adding dissapation).
    (Power MOSFET Bridge Rectifier-Published in issue 356, July 2006)
    (little edit the elektor schema i mentioned is the one you posted (i dont like that one)
    Most simple solution is get some IR1166 of 1167 and build what they present in this paper .
    http://www.irf.com/technical-info/wh.../TP-080527.pdf
    When you have a look at the signals in this paper its clear you can easily do this with simple comperators like lm393 + gatedrivers or even BC transistors building emmiter coupled schmitt triggers .
    (i tryed all these versions and the difference in efficiency is neglectable)
    Personaly i prefer the comperator version for low partcount and ease of getting components .
    Take a transformer with middletap ,this way you can use 2 nmos and take the gatevoltage + supplyvoltage for the comperators etc. from the middletap .
    My prototypes managed 30 Amperes at a loss of 1,2 Watt's in the mosfets (0,58 in every mosfet .
    Its definetly the way to go for big amperes at low loss .
    Good luck :)
    1 members found this post helpful.
    •   Alt2nd June 2009, 19:15
      advertising
  5. #5
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    mosfet rectifier circuit
    Using Mosfets as rectifier is not a difficult job but I find it logical to use for bigger Ampheres like>30A.
  6. #6
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2006
    Wrocław, Poland
    Posts
    62
    Points
    2,159
    Level
    10
    mosfet full wave rectifier
    Doing this for low power applications is not really usefull .
    The cost of components and the space needed for them makes it much more usefull for higher current applications .
    For just a few Amperes ,you could choose the *ideal diodes* from linear .
    But they are just up to 5 Ampere .
    For bigger currents you can design your own or use the IRF chipset where you can go as bad as you like or need .
    (limited by 7A gatedrive capability)
  7. #7
    Full Member level 5
    Points: 3,473, Level: 13
    Join Date
    Mar 2006
    Posts
    276
    Points
    3,473
    Level
    13
    full wave rectifier using mosfet
    Quote Originally Posted by walkura
    Good luck :)
    If you want to go for big amperes and low loss, you want also use all the copper you have in your transformer as much as possible, so a middletap transformer is maybe not so good solution.
    stefaan
  8. #8
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2006
    Wrocław, Poland
    Posts
    62
    Points
    2,159
    Level
    10
    full wave bridge rectifier by using mosfet
    Concerning the middletap .
    You can choose this option to lower your partcount .
    In itself its no problem to build a Graetzbridge with 4 mosfets ,but it is more then twice the amount of parts .
    For me here in Poland ,using a middletap transformer is a cheaper option then adding 2 extra IR1167 + mosfets .
    My reason for using that setup is strictly a economical + ease of production .
    •   Alt18th July 2009, 08:55
      advertising
  9. #9
    Points: 17,543, Level: 32
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,438
    Points
    17,543
    Level
    32
    Re: Full wave rectifier using Mosfets??
    For anyone still interested in this, here's a fairly simple MOSFET bridge rectifier circuit.
    Zapper
    Curmudgeon Elektroniker
