what's the difference between GSM 900 and GSM 1800 ?
desperado1
Full Member level 3
difference between gsm900 and gsm1800
difference between gsm 900 and gsm 1800
the difference is in their operating frequency
and 1800 also have an increased bandwidth
difference between gsm and egsm
just
GSM 900 * 2 = GSM 1800
:D Joking!
as you can find out by its name that the difference is bandwidth.
GSM networks operate in a number of different frequency ranges. Most 2G GSM networks operate in the 900 MHz or 1800 MHz bands. Some countries in the Americas use the 850 MHz and 1900 MHz bands because the 900 and 1800 MHz frequency bands were already allocated. Most 3G GSM networks in Europe operate in the 2100 MHz frequency band.
gsm 1800 channels
GSM-900 and GSM-1800 are used in most parts of the world: Europe, Middle East, Africa, Australia and most of Asia. In South Americas it is in Costa Rica (GSM-1800), Brazil (GSM-850, 900 and 1800), Guatemala (GSM-850, GSM-900 and 1900), El Salvador (GSM-850, GSM-900 and 1900).
GSM-900 uses 890–915 MHz to send information from the mobile station to the base station (uplink) and 935–960 MHz for the other direction (downlink), providing 124 RF channels (channel numbers 1 to 124) spaced at 200 kHz. Duplex spacing of 45 MHz is used. Guard bands 100 kHz wide are placed at either end of the range of frequencies.
In some countries the GSM-900 band has been extended to cover a larger frequency range. This 'extended GSM', E-GSM, uses 880–915 MHz (uplink) and 925–960 MHz (downlink), adding 50 channels (channel numbers 975 to 1023 and 0) to the original GSM-900 band. The GSM specifications also describe 'railways GSM', GSM-R, which uses 876–915 MHz (uplink) and 921–960 MHz (downlink). Channel numbers 955 to 1023. GSM-R provides additional channels and specialized services for use by railway personnel.
All these variants are included in the GSM-900 specification.
GSM-1800 uses 1710–1785 MHz to send information from the mobile station to the base tranceiver station (uplink) and 1805–1880 MHz for the other direction (downlink), providing 374 channels (channel numbers 512 to 885). Duplex spacing is 95 MHz.
GSM-1800 is also called DCS (Digital Cellular Service) in the United Kingdom, while being called PCS in Hong Kong (not to mix up with GSM-1900 which is commonly called PCS in the rest of the world.)
