16bit timer PWM mode (AVR timer 1) as slow 16bit DAC?
7rots51
avr pwm dac
Can I use 16bit timer in PWM mode (AVR timer 1) as slow 16bit DAC?how?
does it have linearity and precision of 16bit DACs,speed of DAC is not important(10SPS is OK)
avr timer1
Linearity is typically better than standard DAC, based on the inherent linearity of a single bit DA, if the analog circuit is designed suitably. A 2nd or 3rd order low-pass filter is required to suppress the PWM frequency ripple.
avr 16 bit timer
Hi
There is a nice artical on EDN site on using PWM as a DAC by Boni Beaker
All the best
Bobi
