+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 3
    Points: 1,727, Level: 9
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    55
    Points
    1,727
    Level
    9
    The concept of BIT Masking using ANDing and ORing Opertion in 'C'
    8051 BIT MASKING:
    I have to use same PORT (SAY P1) for BCD to 7-Segments and other for four different Switches.
    My Question is:
    How to mask BITS/PINS which does not cause any effect to other pins when i have to acces PORT for BCD to 7 -Segment
    Decoder.
    Please Clear me concept of BIT Masking using ANDing and Oring Opertion in 'C'
    Thanks
    Karan
    •   Alt22nd May 2009, 13:38
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    mask concept in 8051
    AND them with a "1" and OR them with a "0" ..
    rgds,
    IanP
    •   Alt22nd May 2009, 16:46
      advertising
  3. #3
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    55
    Points
    1,727
    Level
    9
    bit masking in c
    Thank For Reply...
    But Please write that more clear.
    •   Alt22nd May 2009, 18:27
      advertising
  4. #4
    Advanced Member level 2
    Points: 6,608, Level: 19
    Kurenai_ryu's Avatar
    Join Date
    Jun 2006
    Bolivia
    Posts
    671
    Points
    6,608
    Level
    19
    masking bits
    I think its OR with a "1" to turn on a bit
    and AND with a "0" to turn off a bit...
    for example to turn on bit 3 (P1.3)
    P1 |= (1<<3); // 0000 1000 in binary, it's bit 3 at 1
    to turn off the same bit 3 (P1.3)
    P1 &= ~(1<<3); // 1111 0111 in binary, it's bit 3 at 0
    but as far as I remember... you could use port bit definition to work on individuals bits...
    #include
    sbit pin=P1^3; //bit P1.3 is named pin
    pin=1; //to turn on...
    pin=0; to turn off...
    well that's bit masking... buuuut maybe you need to out 4 bits for the bcd decoder, leaving the other 4 bits as inputs for the switches...
    let's make it the lower nibble to the bcd decoder (like a 74LS47) and the upper nibble to the 4 individual switches...
    #include  //or someone with port definitions...
    sbit SW1=P1^4; // to read the switches...
    sbit SW2=P1^5;
    sbit SW3=P1^6;
    sbit SW4=P1^7;
    /* routine to out a 4 bit bcd number..*/
    void bcd_out(unsigned char bcd){
     if(bcd>9) bcd=0xF;//turn off, invalid numbers...
     P1=0xF0 | bcd; /*upper bits are inputs, leave them  with 1, lower bits are outputs... out the bcd number */
    the PORT initial value of 0xFF makes the switches as inputs and the bcd decoder (like 7447) shut down...
    this code, is for something like keil C for 8051...(maybe RIDE will work to!)
    Hope it helps...
  5. #5
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    55
    Points
    1,727
    Level
    9
    keil bcd c 8051
    Thanks a lot...
