+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Points: 701, Level: 5
    Join Date
    May 2009
    Posts
    Points
    701
    Level
    floquet ports
    I want to know how I can I use the periodic boundary but also use a floquet port so I can change incident angles. (The excitation is plane wave)
    like the example in the link here:
    http://www.cst.com/Content/Applicati...le.aspx?id=355
    Thanks! (If anyone has made this kind of simulation could upload your structure, that would be very helpful!!):D
    •   Alt18th May 2009, 04:30
      advertising
  2. #2
    Advanced Member level 2
    Points: 7,116, Level: 20
    abdoeng's Avatar
    Join Date
    Feb 2004
    Posts
    648
    Points
    7,116
    Level
    20
    floquet port
    hi
    try look for that title in that site
    i already upload it
    •   Alt18th May 2009, 12:42
      advertising
  3. #3
    Join Date
    May 2009
    Posts
    Points
    701
    Level
    floquet site:edaboard.com
    Hi abdoeng, thanks for your reply, but which title and which site???.....
    could you give me a link?? THANKS!!
    Mengkun
    1 members found this post helpful.
    •   Alt18th May 2009, 13:22
      advertising
  4. #4
    Junior Member level 3
    Points: 1,868, Level: 10
    Achievements:
    7 years registered
    Feri4030's Avatar
    Join Date
    Feb 2009
    Persia
    Posts
    31
    Points
    1,868
    Level
    10
    Re: Periodic boundary and floquet port
    The phase different between master boundary and slave boundary determines the incident angle. For example phase difference 0 (both in x directed and y directed x master/slave pairs) means normal incidence.
  5. #5
    Newbie level 5
    Points: 1,245, Level: 7
    Join Date
    Aug 2009
    iitmadras,chennai
    Posts
    10
    Points
    1,245
    Level
    7
    Re: floquet port
    hi,
    I am using HFSS for UNIT-CELL simulation.
    I want to know how to change the incident angle of plane wave in Floquet port.
    I will be great full to you if you suggest
    •   Alt10th May 2011, 16:36
      advertising
  6. #6
    Achievements:
    7 years registered
    Feri4030's Avatar
    Join Date
    Feb 2009
    Persia
    Posts
    31
    Points
    1,868
    Level
    10
    Re: floquet port
    Quote Originally Posted by mohanbabuiitm View Post
    hi,
    In the Floquet port wizard, check the "use scane angles to calculate ..." you can set incident angle, phi and theta, respect to the global coordination system
