+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 3
    Points: 1,104, Level: 7
    Join Date
    Sep 2007
    Posts
    27
    Points
    1,104
    Level
    7
    how can i multiply two signals using common componets?
    hi there,
    i want to step up 100 khz frequency to 30 MHz by multiplying it by Abt 30 MHz frequency... can any one tell me any easy method to MULTIPLY TWO HIGH FREQUENCY SIGNALS upto 30 MHz using opamps , transistors or extremely common ics??
    •   Alt11th May 2009, 13:29
      advertising
  2. #2
    Full Member level 4
    Points: 3,391, Level: 13
    smxx's Avatar
    Join Date
    Aug 2005
    iran(ahwaz)
    Posts
    194
    Points
    3,391
    Level
    13
    you have to build log and anti log amplifier. It so difficult.
    •   Alt12th May 2009, 04:49
      advertising
  3. #3
    Super Moderator
    Points: 241,686, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,965
    Points
    241,686
    Level
    100
    Re: how can i multiply two signals using common componets?
    log-antilog analog mutipliers are of no use in frequency mixing.
    Balanced mixers (diode quartetts or analog 4-quadrant multipliers) give the best performance and a considerable suppression of input signals, which is an important advantage, if the output frequency is near to one of the input frequencies. On the other hand, any non-linear component, e.g. a diode or transistor amplifier with sufficient drive signal can be used for frequency mixing. Balanced mixers with supplementing signal transformers are availiable as RF building blocks, e.g. from mini-circuits.com.
    For 30 MHz, which isn't really a high frequency, an active balanced mixer (analog 4-quadrant multipliers) can be made from 6 individual transistors or diff-amp transistor arrays. Also CMOS analog switches can be used, if the 30 MHz carrier has a digital level.
    •   Alt12th May 2009, 08:54
      advertising
  4. #4
    Join Date
    Sep 2007
    Posts
    27
    Points
    1,104
    Level
    7
    can u tell me how???
    if u use op-amp it would be very easy for me to construct. because transistor thing requires too much passive components which makes the end circuit so messey
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,965
    Points
    241,686
    Level
    100
    It's basically a nonlinear circuit and 30 MHz isn't the domain of typical common OPs.
    As another point, even a perfect double balanced mixer generates two output frequencies f1+f2 and f1-f2. If f2 >> f1, as you intend, it's difficult to filter only one of the components.
    In other words, I miss necessary specification details for a meaningful suggestion.
