PowerPCB pads with holes?
davorin
Advanced Member level 3
Switzerland
Can PowerPCB output layers to printer with holes in pads?
Didn´t see any options like that..
Would be much easier for quick prototyping...
One idea, is to right-click on top of your pad and select Add Via at SMD. Then you just select the via type in (right click in via) Query/Modify.../PadStack, and change the drill size value to say 20 or 30 so that you'll have a hole. Be careful though with the clearances.
Hope that helps
Can you explain a bit more clearly please? I couldn't do it?
I'm not talking about SMD pads...
I mean normal through-hole pads...
In OrCAD there was an option to print the layout to a printer with holes in the pads...but I assume PowerPCB hasn't this feature at all..
Hi davorin, Here is the tips :
U have to redefine all the pad stack with the third pad shape (with a hole inside)
click the check box "Pad size relative to drill size" and then put 0 for the "inner diam"...
then you'll have a pad with a hole (which will be be at the size of the drill)
bye
What about non circular pads?
I've tried but not manage to have a square pad with hole... if anyone knows a solution, plz write it below...
the best way is that
assign a layer for pad master.
define the size of hole u need in the pad durring output.
take the gerber of the same
and while ploting merge it with the soldermask.and inverse this layer over it.
binu george
Sorry but i didn't understand clearly. What is pad master?
this is a reference layer used for manual drill.
a pad with a center open is known as pad master.
when cnc drill is done this never come to a pitcure
binu g
Import all gerber and nc drill files to any gerber editor
Convert drill to gerber data. change polarity of converted gerber data
overlap with other pad layer
then print it
