+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 2,206, Level: 10
    Achievements:
    7 years registered
    saumya_85's Avatar
    Join Date
    Mar 2009
    INDIA
    Posts
    107
    Points
    2,206
    Level
    10
    Could Any body help me out regarding PCB standard?
    Any information regarding IPC-600 or ANSI/IPC-A-610 standard?
    •   Alt5th May 2009, 14:53
      advertising
  2. #2
    Member level 1
    Points: 1,334, Level: 8
    Join Date
    Jun 2006
    Austin, TX
    Posts
    33
    Points
    1,334
    Level
    8
    Re: Could Any body help me out regarding PCB standard?
    IPC specs, (there are a few of them) all have to do with 'quality' of a PCB. ie: does it have less than "x amount of this, or y amount of that". Generally, a common board doesn't have to worry about it, as most PCB fab houses produce acceptable boards. It's mostly for people that want to pay for the extra added assurance that the board will be a 'good' board. Perhaps medical equipment, military, or even some FDA stuff. Unless someone specifically requires it, chances are, you don't need it. And, if you do need it, simply ask your board fab house to fab to "those" specifications. Most of the big players can. I think I've been asked to deliver to that spec perhaps two times in my life, and that was simply because someone 'heard from there counter parts' that it was better. But again, in todays times, if a board fab house can't turn quality boards, they won't stay in the game that long.
    -Mike
    www.pcb-experts.com
    1 members found this post helpful.
