+ Post New Thread
Results 1 to 4 of 4
1st May 2009, 03:34 #1
- Join Date
- Mar 2008
- Posts
- 305
- Helped
- 2 / 2
- Points
- 3,568
- Level
- 14
advantage of active filter
Hi Guys
what is the advantages of active filter? The only advantage I can think is active filter can give you, is there any other reasons for it?
Thanks,
1st May 2009, 03:34
1st May 2009, 04:52 #2
- Join Date
- Oct 2006
- Posts
- 69
- Helped
- 4 / 4
- Points
- 2,590
- Level
- 11
why do we use active filter
basically you can adjust gain
1st May 2009, 04:52
1st May 2009, 05:25 #3
- Join Date
- Jan 2009
- Location
- India
- Posts
- 211
- Helped
- 26 / 26
- Points
- 2,842
- Level
- 12
why we use active filter
almost free from input and output impedance changes
1 members found this post helpful.
1st May 2009, 05:25
1st May 2009, 08:42 #4
- Join Date
- May 2008
- Location
- Germany
- Posts
- 5,689
- Helped
- 1706 / 1706
- Points
- 39,702
- Level
- 48
Re: why do we use active filter?
Originally Posted by liletian
1.) Most important: No inductances, which are heavy, expensive, sensitive to electro-magnetic effects, not integrateable, not easy to tune, ....
2.) Filter design is easy, as you only need to caculate 2nd order stages, which can be cascaded to higher order filters (because of low output impedances)
3.) They can be tuned by voltages or currents
4.) They can provide gain
5.) Active filter topologies can be fully integrated (OTA-C or gm-C approaches)
6.) They are the basics to design S/C filters
+ Post New Thread
Please login
