HD44780 20x4 LCD display and PIC18F252 for battery monitor
richie244
Newbie level 2
pic18f252
I am currently doing a project using HD44780 20x4 LCD display and PIC18F252 to produce a simplistic Battery monitor. At the moment all I wish to achieve is taking a voltage from a shunt amplified to around 3v and the voltage from the battery reduced to 3v and display these on the LCD display. obviously the voltage acros the shunt is proportional to the Current so I wish to display this as a current on the screen.
The hard ware andtheory side of this is simple for me where I fall over is the programming as I have no experience in this field I have written (comme across) the following I think the initial part is ok but I am really strugling with the LCD Display.
#include <p18f252.h>
#include <stdlib.h>
#include <string.h>
#include <delays.h>
void Initial()
	TRISA = 0xFF; // port A, all bits, inputs
	TRISB = 0x00;
	ADCON1 = 0b10000000; //AD port configuration
					     //AAAAAAAA VDD VSS
	ADCON0bits.ADCS1=1;
	ADCON0bits.ADCS0=0;  // ADC clock = Fsoc/32
	ADCON0bits.CHS2 =0;
	ADCON0bits.CHS1 =0;
unsigned char readADC(int ch){
	unsigned char adcValue;
	if(ch == 0) ADCON0bits.CHS0 =0;  // select channel 0
	else        ADCON0bits.CHS0 =1;
	ADCON0bits.ADON =1;  // turn on ADC
	ADCON0bits.GO_DONE = 1; 	// start conversion
 	while(ADCON0bits.GO_DONE) 	// wait for conversion end
    adcValue = ADRESH;
	return adcValue;
void LcdEnable();
* Display
   #define   lcd_rs   PORTCbits.RC2
   #define   lcd_rw   PORTCbits.RC3
   #define   lcd_e   PORTCbits.RC4
   #define   lcd_cmd_wri   0x00
   #define   lcd_data_wri   0x01
   #define   lcd_busy_rd   0x02
   #define   lcd_set_function   0x3C   //00111100 8 bit interface, 4 line mode, 5x11 dot format
   #define   lcd_set_visible   0x0F    //Display on, cursor underline on, cursor blink on
   #define   lcd_set_shift   0x16      //Cursor move, Right shift
   #define   lcd_set_mode   0x06       //Increment, display shift off
   #define   lcd_set_cgaddr   0x40
   #define   lcd_set_ddaddr   0x80
   #define   lcd_clr   0x01
   #define   lcd_init   0x30
   #include <stdio.h>
   #include <stdlib.h>
   #include <string.h>
   int i,j;
   const int Twentyms = 640000;
   const int Tenms = 320000;
   const int Onetwofivems = 4000000;
   const int Twohundredus = 6400;
   const int Onehundredus = 3200;
   const int Sixtyfourms = 2048000;
void WrCmd2Lcd(char cmd);
void WrDat2Lcd(char data);
void InitLcd();
void Speech(char words,int position);
void LcdWait();
void LcdPutPar(int par);
void LcdEnable()
   lcd_e=1;
   j=Tenms;
   for (i = 0; i < j; i++); //delay for 10ms
   lcd_e=0;
   TRISB = 0x00;
   lcd_rw=0;
   lcd_rs=1;
   PORTB=cmd;
   LcdEnable();
   TRISB =0x00;
   lcd_rw=0;
   lcd_rs=0;
   PORTB = data;
   LcdEnable();
void InitLcd()
   lcd_e=0;
   j=Onetwofivems;
   for (i = 0; i < j; i++); //delay for 125 ms
   WrCmd2Lcd(lcd_init);
   j=Twentyms;
   for (i = 0; i < j; i++); //delay for 20ms
   LcdEnable();
   j=Twohundredus;
   for (i = 0; i < j; i++); //delay for 200us
   LcdEnable();
   j=Onehundredus;
   for (i = 0; i < j; i++); //delay for 100us
   WrCmd2Lcd(lcd_set_function);
   j=Tenms;
   WrCmd2Lcd(lcd_set_visible);
   j=Tenms;
   WrCmd2Lcd(lcd_clr);
   j=Onehundredus;
   WrCmd2Lcd(lcd_set_mode);
   j=Tenms;
   WrCmd2Lcd(lcd_set_ddaddr);
   j=Onehundredus;
void LcdWait()
   int status;
   TRISB=0xFF;
   TRISB = lcd_busy_rd;
   do
      lcd_e=1;
      status = ADCON1;
      lcd_e=0;
   while(status & 0x80);   // test busy flag.
char *textptr;
   //textptr = words;
   WrCmd2Lcd(position);
   LcdWait();
   j=Sixtyfourms;
   for (i = 0; i < j; i++); //delay for 64ms
   do
   WrDat2Lcd(*textptr);
   *textptr++;
   while(*textptr != '\n');
    TRISBbits.TRISB0 = PORTBbits.RB0,par & 0X01;
    TRISBbits.TRISB1 = PORTBbits.RB1,par & 0X02;
    TRISBbits.TRISB2 = PORTBbits.RB2,par & 0X04;
    TRISBbits.TRISB3 = PORTBbits.RB3,par & 0X08;
 	TRISBbits.TRISB0 = PORTBbits.RB4,par & 0X10;
    TRISBbits.TRISB1 = PORTBbits.RB5,par & 0X20;
    TRISBbits.TRISB2 = PORTBbits.RB6,par & 0X40;
    TRISBbits.TRISB3 = PORTBbits.RB7,par & 0X80;
void main(void) {
	unsigned char voltage1, voltage2;
	while(1){
//	 	voltage1 = readADC(0);
//	 	voltage2 = readADC(1);
		InitLcd();
//		WrCmd2Lcd(0X06);
//		LcdEnable();
  		WrDat2Lcd("A");
//		LcdWait();
		while(1);
