+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 3
    Points: 9,408, Level: 23
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    difference between orthogonal and orthonormal
    Hey, I have a question, what is the difference between Orthogonal and Orthonormal?
    Do they mean same thing? Like the inner product is equal to zero
    •   Alt21st April 2009, 15:49
      advertising
  2. #2
    Newbie level 6
    Points: 790, Level: 6
    Join Date
    Apr 2009
    Posts
    12
    Points
    790
    Level
    orthogonal and orthonormal signals
    orthogonal as u said
    but orthonormal is orthogonal and normalized at same time
    1 members found this post helpful.
  3. #3
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    orthogonal perpendicular difference
    please elaborate. what do you mean by "orthogonal & normailized at the same time"
  4. #4
    Newbie level 5
    Points: 1,127, Level: 7
    Join Date
    Feb 2009
    Posts
    10
    Points
    1,127
    Level
    7
    orthogonal mean the same as orthonormal
    Orthogonal mean that the dot product is null.
    Orthonormal mean that the dot product is null and the norm is equal to 1.
    If two or more vectors are orthonormal they are also orthogonal but the inverse is not true.
    •   Alt22nd April 2009, 05:50
      advertising
  5. #5
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    difference orthogonal orthonormal
    what is "norm" what are its benefits?
    I've seen it being used many time in place of square of a vector of variables
  6. #6
    Newbie level 5
    Join Date
    Feb 2009
    Posts
    10
    Points
    1,127
    Level
    7
    convert orthogonal to orthonormal function
    norm(u) is defined by <u,u> where <,> is a dot product and u a vector.
    A norm depends on the dot product you chose to use.
    What do you mean by "the benefits of the norm"?
  7. #7
    Newbie level 6
    Join Date
    Apr 2009
    Posts
    12
    Points
    790
    Level
    difference between orthorgonal and orthonormal
    first the using of orthonormal as basis functions so it should be normalized
    and when we do dot product of two orthogonal functions the result is zero
    but when we do dot product for orthogonal function with itself the result will be constant or 1 if they normalized
    so it is easier to use orthonormal from beginning to simplify the computations
    refer to signal space
    when we use orthonormal functions as basis functions so the amplitude of signal is square root of signal -will get the meaningful representation of signal -in direction of this basis
    and for any other signal,u need to get the projection in this basis u need to get ratio between two amplitudes -signal and basis function if the basis function is not normalized-
    •   Alt22nd April 2009, 17:00
      advertising
  8. #8
    Full Member level 3
    Points: 3,748, Level: 14
    Join Date
    Jul 2006
    Bahrain
    Posts
    183
    Points
    3,748
    Level
    14
    orthogonal and orthonormal functions
    Orthonormal means orthogonal (perpendicular) and the length of that vector equals to one.
    Regards
  9. #9
    Newbie level 3
    Points: 158, Level: 2
    Join Date
    Mar 2014
    Posts
    Points
    158
    Level
    Re: difference between orthogonal and orthonormal
    • A nonempty subset S of an inner product space V is said to
    be orthogonal, if and only if for each distinct u, v in S, [u, v] = 0. However, it is orthonormal, if and only if an additional condition – for each vector u in S, [u, u] = 1 is satisfied.
    • Any orthonormal set is orthogonal but not vice-versa.
    • Any orthogonal set corresponds to a unique orthonormal set but an orthonormal set may correspond to many orthogonal sets.
