+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 2
    Points: 655, Level: 5
    Join Date
    Apr 2009
    Posts
    Points
    655
    Level
    pickit2 16f84a
    Hi All,
    Reacently I brought Pickit 2. Can anybody help me to program pic 16F84 by it. I need connector circuit diagram. It need RC ocillator for that circuit? Thanks..
    Amil
    •   Alt21st April 2009, 02:30
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    pickit 2 16f84
    Hai Amil
    Guess you have got a CD with the PiCkit2 when you bought it, which will havve a user maual which will guide you in programming the devices. Below given schematic gives you the programmer Pin out. You may also download the Pickit2 user manual from this address. Hope it HELPS you. http://ww1.microchip.com/downloads/e...Doc/51553B.pdf
    •   Alt21st April 2009, 09:21
      advertising
  3. #3
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    pickit2 pic16f84
    Hi Amil,
    For pic 16f84, connect in the following way:
    Pin 1 to pin 4 of ucontroller
    Pin 2 to pin 14 of controller
    pin 3 to pin 5 of controller
    pin 4 to pin 13 of controller
    pin 5 to pin 12 of controller
    Oscillator is not required here. You just connect the Pickit 2 with the above mentioned pins of pic16f84 and program with software. It will suffice. Thanks.
    •   Alt22nd April 2009, 07:43
      advertising
  4. #4
    Points: 14,575, Level: 29
    blueroomelectronics's Avatar
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    pickit 2 16f84a
    The PICkit2 doesn't support the 16F84 it does support the 16F84A
  5. #5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    pickit connection
    The Pic16F84 is a realy old and expensive micro, in fact it was the first pic to feature flash memory, before that, they were all one time programable chips.
    Ditch the thing and get something like the Pic16f883 series.
    Much more powerful and a lot cheaper.
