+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Points: 8,722, Level: 22
    Join Date
    Feb 2002
    Posts
    1,435
    Points
    8,722
    Level
    22
    The cheapest PLC around (from OLIMEX)
    I wanted to design a LOW COST PLC ..So last night TV programing was BORING .and HEAVY SNOW was falling .While waiting for answers to SOME questions that I POSTED at ELEKTRODA .. I discovered the OLIMEX AVR-IO board going for $25 bucks.
    http://www.olimex.com/dev/index.html
    Ok .. To be really a PLC .. You have to programme it in some kind of LADDER scheme ..
    Well i have ladderworks a great compiler of LADDER designs The only problem is that the output is Binary 51 code ..(Hex)
    Well if there was a possibility of changing the AVR chip for a 8051 .. I will be in heaven .The AVR-IO board cames with a AT90S2313 chip .But it turns out that that 20 pin chip is PIN TO PIN compatible with another CHEAP CHIP($3.00) from also ATMEL ..the AT89C4051 with 4k flash code!
    Now i'm in heaven $30 dollar PLC that i can programme ( JUST FOR TEACHING PURPOSES for me )
    The only PROBLEM is that i can't use a BOOT LOADER .. this chip doesn't support on board programming .. It's Ok to remove the chip for that
    PRICE .. i won't be that demanding .
    I will change the quartz clock to run it at full speed 24 Mhz!
    I love snowy day ... and cognac...(the cheap one)!
  2. #2
    Full Member level 4
    Points: 4,651, Level: 16
    Join Date
    Nov 2001
    Posts
    236
    Points
    4,651
    Level
    16
    cheapest plc
    For teaching is OK, but why you don't use a simulator?
    •   Alt18th February 2004, 19:22
      advertising
  3. #3
    Junior Member level 1
    Points: 2,233, Level: 10
    Join Date
    Apr 2002
    mars
    Posts
    16
    Points
    2,233
    Level
    10
    plc cheap
    Hi, friends.
    There is a new small PLC from the chinese factory Array, it cost me only 35 US dollars and has many interesting characteristics such as real time clock, function block programming.
    Using any search engine the array´s webpage could be located.
    •   Alt20th February 2004, 01:01
      advertising
  4. #4
    Points: 2,179, Level: 10
    Join Date
    Jan 2002
    Posts
    16
    Points
    2,179
    Level
    10
    plc array fab rs232 forum
    Hi unimx,
    Cannot find it. Why not give the website?
    •   Alt14th June 2004, 21:17
      advertising
  5. #5
    Member level 2
    Points: 3,271, Level: 13
    Join Date
    Oct 2001
    good old europe
    Posts
    50
    Points
    3,271
    Level
    13
  6. #6
    Full Member level 1
    Points: 2,439, Level: 11
    Join Date
    May 2004
    Posts
    117
    Points
    2,439
    Level
    11
    cheap p.l.c.
    try to use zelio from shneider also they have a great simulator
  7. #7
    Advanced Member level 1
    Points: 5,685, Level: 17
    Join Date
    Feb 2002
    Italy
    Posts
    411
    Points
    5,685
    Level
    17
    the chipeast plc
    If You read Italian, go to ww.elestream.it; they have the cheapest PLC's.
    Mandi
  8. #8
    Member level 2
    Points: 2,158, Level: 10
    Join Date
    Oct 2001
    Argentina
    Posts
    44
    Points
    2,158
    Level
    10
    olimex avr-io rs232
    Try with FESTO FEC PLC line.
    It is very cheap, and have some powerfull capabilities:
    - ethernet port integrated
    - rs232 master messaging
    - DOS system operating
    - 256 Kb of retentive memory
    - 2 msec scan time for 1k instructions
    - don't have battery (no manteninance)
    - can be directly connected to a analog/digital converter also very cheap
    •   Alt27th June 2004, 17:09
      advertising
  9. #9
    Member level 2
    Join Date
    Oct 2001
    Argentina
    Posts
    44
    Points
    2,158
    Level
    10
    low profile cheap plc
    Also if you want to design a cheap PLC try with the IPC integrated circuit from BECK: www.beck-ipc.com
    They have a powerful integrated circuit that can handle directly a ethernet port for example.
