+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Points: 15,530, Level: 30
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    Explanatio of 16-QAM and QPSK statements
    can anybody explaine the following please:
    16 QAM with code rate of 1/2 coding to give 2 bits per symbol.
    and
    QPSK with code rate of 3/4 coding to give 1.5 bit per symbol.
    also if you know the reference, please advise me
    thanks in advance.
  2. #2
    Member level 4
    Points: 1,362, Level: 8
    Join Date
    Dec 2008
    Posts
    76
    Points
    1,362
    Level
    8
    qpsk coding rate
    16 QAM produces 4 bits/symbols with an (1/2) rate (bits/symbol) coding will produce
    4*(1/2)=2 bits/symbols
    2 * (3/4) = 1.5bit/ symbol
    whether the explantion is enough for you or are u expecting some other reply.
    Happy Learning
    1 members found this post helpful.
  3. #3
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    16qam
    My Friend,
    If i have 128 binary digits and need to use the QPSK modulation, then the number of output symbols will be 64, in each symbol there are 2 bits. Now if i used the QPSK with 3/4 coding, what is the outbut will be?
    •   Alt26th March 2009, 15:08
      advertising
  4. #4
    Newbie level 6
    Points: 824, Level: 6
    Join Date
    Mar 2009
    Posts
    12
    Points
    824
    Level
    qam 16 3/4
    may i know the clarification also?
    Thank you
    •   Alt26th March 2009, 17:00
      advertising
  5. #5
    Member level 4
    Join Date
    Dec 2008
    Posts
    76
    Points
    1,362
    Level
    8
    16 qam bitrate
    At first what is the your bit rate(source bit rate=R_s)?????
    if there are k=128 bits for (1/2) rate coder, there are 100% redundant bits (n-k)
    i.e., 128 bits. ; n=128+128=256.
    so code rate=r=k/n=128/256=1/2.
    channel encoder bit rate is given by = R_c= (n/k)*R_s = (256/128)*R_s =2*R_s
    where R_s is the bit rate generated by the source.
    If R_s is the bit rate which is incoming bits to the encoder.
    the o/p of the M-ary modulator in your case QPSK (M=4, in this case)
    At the o/p of the M-ary modualtor: symbol rate R_sym
    R_sym= R_c / log2 (M) = 2*R_s / log2 (4) = R_s in your case.
    Happy learning
    •   Alt26th March 2009, 18:00
      advertising
  6. #6
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    qam bit rate
    My friend,
    Thank you for your help, but i am asking about the number of output symbols in case of QPSK with code rate of 3/4 coding if the input is 128 bit.
    please rectify me if i am asking something wrong. In OFDM i need to know what is the data that i have before i process it by the IFFT block.
    Many Thanks
  7. #7
    Member level 4
    Join Date
    Dec 2008
    Posts
    76
    Points
    1,362
    Level
    8
    16 qam coding rate
    If the i/p bit is transferred at the rate of 128 bits/ sec.
    then in case of of QPSK (M=4) with code rate of 3/4 coding
    Rc= (3/4)*128 = 96
    NO. OF SYMBOLS TRANSFERRED AT THE O/P QPSK MODUALTOR IS : 96/log2 (4) = 96/2 = 48 symbols/sec
    i think this will help you to further proceed in your learning.
    Happy learning
    Added after 5 minutes:
    hVE YOU GOT CONVINCED OR ARE YOU EXPECTING ANOTHER BETTER REPLY.
    WHETHER YOU CHECKED WITH MY ANSWER ???? I HAVE SHARED MY KNOWLEGE WITH YOU.
    KINDLY CHECK WITH THE ANSWER AND DO REPLY ME.
  8. #8
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    qam code rate
    I donate 50 points for you. Your discussion was very clear and good.
    Many thanks.
    by the way, there are about 10 new members from Malaysia joined our group all are students of PhD and M.s.c in communications. Most of them are Iraqi students. So that, Please rewrite your answer in the group as this very nice from you
  9. #9
    Member level 4
    Join Date
    Dec 2008
    Posts
    76
    Points
    1,362
    Level
    8
    qpsk code rate
    Hi Muntather,
    "Please rewrite your answer in the group as this very nice from you "
    i can't follow this line.
    what do you mean by that.....
    Happy learning
  10. #10
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    qam coding rate
    just to put some force in the group. May be this will help some of the members. I do not mean other thing. My Friend,
    My goal is to let every one learn.
    I am sorry if you understand it in a wrong way.
  11. #11
    Advanced Member level 3
    Points: 9,408, Level: 23
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    16 qam symbol rate
    Quote Originally Posted by rramya
    How can the (data) rate change? Doesn't the channel encoder just add redundency at the same data rate of the incoming stream.
    2*R_s shows that after suppose convolutional encoding the data rate of the encoded symbols is greater than the data rate of the incoming bit stream.
    I think the data rate remains same, only that now you have half of the user bits flowing in the same amount of time.
    Secondly, the idea about the 1.5 bits/symbol ... I think this is related to information theory, we dont have a 0.5 bit practically. I am completely convinced by the math that you have provided but this shows that in one symbol after encoding there would be equivalent information to 1.5 bits. Even though the symbol would really be carrying 2 bits i.e. 2 bits/symbol
    Do you agree? Y/N
    •   Alt2nd April 2009, 07:27
      advertising
  12. #12
    Member level 4
    Join Date
    Dec 2008
    Posts
    76
    Points
    1,362
    Level
    8
    qam 16 1/2
    ANS: YOU R CORRECT:
    i never talk abt data rate change!!!!
    all i talk abt
    the channel encoder rate ... because of adding redundant bits....
    eg in case: for convolutional encoder rate of (1/2)
    which means: we require double the bandwidth of the uncoded Systems.....and hence the capacity of the channel needs to be doubled for the . hence R_c=2*R_s
    INTREPRETATION:
    since BW is a constrainst,
    if we cant double the bandwidth of the single user channel: automatically,
    ONLY HALF OF THE USER BITS ARE TRANSMITTED in the given channel , utilizing the available BW.
    Secondly, the idea about the 1.5 bits/symbol :
    suppose if R_s = 3 bit/sec.... encoder rate = (3/4)
    R_c=(4/3)R_s =4 bit/sec
    Here , we have original bits = 3 bits
    redundant bit = 1 bit
    At the Modulator o/p , the symbol rate is R_Mod_sym = R_c/log2(M)
    for QPSK M=4.
    R_Mod_sym = R_c/log2(M) = ( 4 ) / log2(4) = 4/( 2) = 2 symbols /sec
    now,
    bits/symbol = 3 (bit/sec) / (2 ) (symbols /sec) = (3/2) bits / symbol...
    = 1.5 bits/symbol
    INTREPRETATION:
    we have 3 bits as original bits there are 2 symbols (which has got 2 bits/symbol, in case of QPSK) we get at the o/p of the modulator ......
    bits/symbol = 1.5 bits/symbol ..............
    Happy Learning.
  13. #13
    Newbie level 1
    Points: 585, Level: 5
    Join Date
    Sep 2009
    Posts
    Points
    585
    Level
    16 qpsk
    Hi, Im looking for an answer with a problem that I have with my wireless connection.
    The antena outside my house has very high signal but the modulation fluctuates too much. For example:
    QAM64 3/4
    QAM16 1/2
    QAM16 3/4
    QPSK 3/4
    Data ranges for download and upload of 29+
    It seems that this fluctuations are affecting my internet connection. I'm experiencing also fluctuations on connection timeouts (Sporadic connection timeout). This is affecting my downloads and other communication that requires stable connection.
    Do anyone knows if its possible to fix a wireless antena with just one modulation?
    Thanks for any help
    QLands
