help with oscillator - 5Mhz crystal connected to inverters
scanpatton
Newbie level 3
hi can someone please help me.. I need a 5Mhz oscillator.. I was told that the simplest way is use a 5Mhz crystal connected to inverters...but here lies the problem..electronics isnt my field :!::?::!: .. could anybody please tell me how this is connected or a even circuit diagram would be brilliant..
would really appreciate it.....
Thanks
Re: help with oscillator
If you don´t need prcision and stability you can do this **broken link removed**
If you need stability you can do this https://www.icbase.com/pdf/add/ti/AN-101-00039en.pdf At 5MHz any suitable 74HCxx or 75HCT inverter will do the job. Please google for a while and you´ll find lots of references.
