+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 3
    Points: 2,906, Level: 12
    Join Date
    Sep 2006
    Posts
    189
    Points
    2,906
    Level
    12
    chebyshev filter
    what's the basic differences between butterworth & chebyshev filter ?
    •   Alt25th March 2009, 03:59
      advertising
  2. #2
    pauloynski
    butterworth chebyshev filter
    Here is a comparison. Please google for a while to find many others. http://en.wikipedia.org/wiki/Chebyshev_filter
    Added after 1 hours 42 minutes:
    Download and install FilterPRO to simulate them http://focus.ti.com/docs/toolsw/fold...filterpro.html
  3. #3
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    butterworth and chebyshev filters
    In words:
    Butterworth low pass exhibits a maximally flat response within the pass region;
    Chebyshev response has some ripple within this region, however, in the transition region it is somewhat steeper.
    •   Alt25th March 2009, 08:55
      advertising
  4. #4
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    chebyshev butterworth
    desperado1,
    The Butterworth filter is maximally flat It optimal is in the sense that of all possible filters with a monotonic passband and a monotonic stop band, it has the minimum attenuation in the pass band.
    The Chebychev filter is optimum in the sense that of all filters with a monotonic stop band (ripple allowed in the passband), it has the steepest transition region.
    Regards,
    Kral
  5. #5
    Banned
    Points: 8,487, Level: 22
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    Posts
    1,180
    Points
    8,487
    Level
    22
    ALSO THINK WHAT PHASE SHIFT EACH FILTER GIVES.AND THE LEVEL OF DISTORTION (sorry about caps)
    •   Alt29th March 2009, 16:03
      advertising
  6. #6
    Advanced Member level 1
    Points: 4,634, Level: 16
    xulfee's Avatar
    Join Date
    May 2008
    Pakistan
    Posts
    401
    Points
    4,634
    Level
    16
    chebyshev butterworth filters
    both r basically mathematical function,butterworth is flat in it pass band but it's transition band is not much abrupt,where chabyshev has ripples in pass band but its transition band is abrupt so it signal dies out quickly,
    it is basically trade off b/w passband n transition band
  7. #7
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    The phase linearity of the Butterworth is better than that of the Chebyshev. In other words, the group delay (derivative of phase with respect to frequency) is more constant with respect to frequency. This means that the waveform distortion of the Butterworth is lower. Of course, with a single input frequency, there is no waveform dostortion in either filter.
    Regards,
    Kral
    Added after 4 minutes:
    Another point to consider; the Butterworth filter is completely defined mathematically by 2 parameters: Cutoff frequency and number of poles. The Chebyshev filter has a third parameter: Passband Ripple.
    Regards,
    Kral
