jpsmith123
Full Member level 2
I've got a relatively simple coaxial structure for which I want to determine the approximate inductance.
I thought that if I excite it with a voltage pulse using a discrete port and select "Monitor voltage and curent" (under port properties), there would be some post-processing template that would give inductance. Instead I get an error message: "Template based postprocessing result "L_path1_path1":
Error in calling "Evaluate0D" function (Inductance matrix value not available)".
I'm wondering, does anyone know how to make it calculate inductance? Thanks.
