Sending/receiving data using FT232RL and prolific
nandhu015
Advanced Member level 5
India
Hai
Does any one tried FT232RL at 115200 baud rate.
FT232 works at this baud rate, iam able to send and receive data from pc to microcontroller (atmega8).
But compared to prolific it seems to be very slow.
Iam able to send 1Mbytes data in ~2minuts with prolific while FT232 is very very slower. with the same hardware
Can anybody guide me in this problem
Nandhu
ftdi vs prolific
FT232 can provide at least full througput with VCOM driver and 920kBaud, or up to 1 MByte/s with native driver. It's most likely a problem of inappropriate API interface usage at the PC side.
ftdi prolific
Thanks FVM
The software is written in VB using mscomm object.
The same is running at full speed with prolific based converter.
Yes i do feel that the driver is the problem
FTDI web site says the chip can drive upto 3Mbytes.
I had asked help from FTDI website, still now i did'nt get any reply, iam waiting for that
Can u help me to get any driver other than the one supplied by FTDI
Reagards
Nandhu
prolific usb ft232r
I'm always using FTDI drivers, but through generic windows API with C++ or Delphi. Did you try to adjust the advanced port settings for the device in system control manager? Also using the FTD2XX driver interface generally achieves higher speed than VCOM.
how to interface ft232r with 89c52
Thanks Fvm
Yes the prob im facing is because of the latency setting.
It is clearly mentioned in the application note of FTDI
There are 2 options left either change the way my micro communication or as you said.
Regards
Nandhu
ft232r и labview
A made a communication with FT232R and Atmega8 on 16MHz. On PC, there was Labview. 1Mbit/s wasn't a problem at all. And there is maximum speed 3Mbits/s and not 3Mbytes/s - that's the big difference. You must use updated d2xx drivers.
Regards.
prolific and ftdi drivers
yes, it will be working if lot of data transfered from one side to another alone. My circuit is designed to reply for each 256 bytes.
There will be problem when a single byte of data is transferred
Thanks for your reply
Regards
Nandhu
+prolific +ftdi
sir,
my project name is smoker's counselor we are using 89C52 micro controller.
it has 3 blocks 1.smoke detector 2.lcd interfacing 3.audio output.
when smoke comes it will detected by the smoke detector and a message like QUIT SMOKING will displayed in the lcd and same will come through audio output.
so here when smoke comes then only lcd is displaying message otherwise it is just neutral now i want the lcd to work for no smoking condition.
so Iam now interfacing DS1307rtc to the 89C52 so that it will display the time and calender when there is no smoke .
actually i don't know how to interface rtc the 89C52 can any one suggest me how to do this.
plz give the C code for this .
prolific vs ftdi
Hai adithyaa
Your post is nowhere connected with rs232 or prolific
why dont you post it as a new topic and every one will see.
Regards
Nandhu
