How to make a state machine of a sequence detector?
spauls
Advanced Member level 2
Can any body tells about how to proceed to make a state machine of a sequence detector ,
regards
so easy problem....
search 'sequence detector' in google.
somebody implemented it by fsm.
Re: Sequence Detector
use shift register and some logic is sufficient.
for exampl, if you want to detect sequence 1011,
you can use following verilog code to do it.
wire signal_in;
wire seq_detected;
reg signal_d1, signal_d2, signal_d3;
always @(posedge clk or negedge rst_n)
if (~rst_n)
begin
signal_d1 <= #1 1'b0;
signal_d2 <= #1 1'b0;
signal_d3 <= #1 1'b0;
end
else
begin
signal_d1 <= #1 signal_in;
signal_d2 <= #1 signal_d1 ;
signal_d3 <= #1 signal_d2 ;
end
assign seq_detected = signal_d3 & (~signal_d2) & signal_d1 & signal_in;
best regards
regards
The answer is described nicely here
