+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 1
    Points: 920, Level: 6
    Join Date
    Jan 2009
    Posts
    34
    Points
    920
    Level
    how to get uncox
    can anyone tell me how to find the values of UnCox and the output resistance(ro) of the transistor(i.e. drain to source resistance)
    I am using a thin oxide transistor W=150nm and L=40nm
    •   Alt12th March 2009, 07:34
      advertising
  2. #2
    Junior Member level 1
    Points: 835, Level: 6
    Join Date
    Oct 2008
    Posts
    15
    Points
    835
    Level
    uncox value
    Hiii
    U can watch all the parameters by simply clicking on the component after performimg simulation. This is according to simulator.
    If u want to calculate theoritically fix the W/L, Id, Vg and Vd and calculate µCox..
    Regards
    Bhargav
    •   Alt12th March 2009, 11:45
      advertising
  3. #3
    Member level 1
    Join Date
    Jan 2009
    Posts
    34
    Points
    920
    Level
    Re: finding the value of UnCox in cadence spectre
    how do i find out the output resistance of the trans...
    •   Alt12th March 2009, 12:14
      advertising
  4. #4
    Advanced Member level 2
    Points: 6,545, Level: 19
    Join Date
    Nov 2005
    canada
    Posts
    529
    Points
    6,545
    Level
    19
    use dc analysis, un, eox, tox, weff, leff, gds are all there in results browser
    all the model parameters for different bsim versions are listed and described here:
    http://www.dianzichan.com/anonymous/...Veiledning.pdf
  5. #5
    Advanced Member level 3
    Points: 6,635, Level: 19
    Sadegh.j's Avatar
    Join Date
    Nov 2006
    Posts
    754
    Points
    6,635
    Level
    19
    Get a basic transistor, have a very very very basic circuit, sweep the gate-source voltage and monitor the drain current
    •   Alt13th March 2009, 02:19
      advertising
  6. #6
    Member level 1
    Join Date
    Jan 2009
    Posts
    34
    Points
    920
    Level
    the value of rout can be found frm the results browser n then selectin the req trans.....the value of µ is also available there
